98 Caravan Cluster prob.
Got a weird problem. The temperature gauge and speedometer does not work. Fuel Gauge works fine, as does the cruise control. When a scanner is hooked up, it reads no response. Drives and shifts perfectly. Also the odometer/tripmeter does not count up while driving.
Figure its not the speed sensor cause the cruise works. Maybe cluster? Although fuel gauge works. Maybe pcm? Any ideas? Its a 3.0 engine. Think it flashes code 55 with the mil lamp. All help appreciated, thank you. |
Re: 98 Caravan Cluster prob.
Try resetting the bcm . Go under the hood in the fuse and relay center above the battery and find the fuse labeled "IOD" near the top, pull that for a couple minutes and see if that helps . sometimes that will fix problems like this and sometimes not .
Read through this thread: http://www.automotiveforums.com/vbul...d.php?t=591775
