Powermaster Alternators
Xeroinfinity or GTPdad since you both seem to be the goto guys for information, what are your thoughts on the Powermaster Alternators?
http://s10planet.performancecenter.c...mber_PRM48137/ The stock alternator that is in the car now was already repaired once by the previous owner. I am thinking of replacing it, and upgrading the amps. At minimum i will replace it with a stock oem. I probably don't need the 140 amps as my stereo, sirius unit, and 2way radio are powered just fine, although i may add more accesories in the future. Moneywise though, minus the core charge from Autozone or napa etc for a replacement... The powermaster is about $1 per amp. Seems like a good bang for the buck over oem. Thoughts, opinions? Cad |
Re: Powermaster Alternators
that 140amps would be at the high rpms.
Its only 80amps at idle. So it should average 120ish. It doesnt look bad,Looks like a Delco, probly cheaper than Napa too. But it might add up after shipping the heavy bugger. the stock ALT are around 100-105amps. Most I replace with a 110-125amp depending on what been added. I buy most of mine from some who I know who rebuilds alt/starters all day long. that would suck ![]() So I'd try and get one at least 110amps, and one 120amps if you are going to be adding big Amps and speakers, AV equipment. Over All that Powermaster does look like a good deal, just make sure it has a good 1-2yr warnty, and how much it is to ship that heavy thing. Just looked over at NAPA thiers are $130-180 depending on what engine. Wasnt sure if your 93' was a 4 or 6 cylinder.
1999 Grand Am SS 3.4 OHV
I agree with Xeroinfinity. You probably will never need that much power regardless of the amount of accessories you add. Actually most ambulances use 140 amp alternators and they have a lot more power requirements than any car would ever have.
