Go Back   Automotive Forums Car Chat > Oldsmobile > Aurora
Old 07-22-2006, 05:50 PM
bugsas99 bugsas99 is offline
Cool front end problem HELP
i have had this problem for a week or so. the left front end is making a moaning sound. and when you hit the brakes quite hard at speed the car jerks to the right like right now. kind of scary. i put 4 brand new tires on today had the car aligned. and nothing same situation. when i hit the brakes the car goes right really hard. the guy at shop said the toe was way off. so i figured problem solved. its a 98 with 142,000 miles. i love the thing to death. that and i owe way more than its worth. any suggestions. rack n pinion, wheel bearing???? please help out guys. this site kicks ass.
Old 07-24-2006, 09:12 AM
aarcuda aarcuda is offline
Re: front end problem HELP
i read a recall on these cars where they had different calipers or rotors on one side making the car pull during braking. search for recalls on these or call the dealer
Old 07-24-2006, 06:19 PM
97 silverbullet's Avatar
97 silverbullet 97 silverbullet is offline
Send a message via AIM to 97 silverbullet Send a message via Yahoo to 97 silverbullet
does it pull when your not braking? check your calipers you might have one of them sticking
[On his running for California Governor]
It's the most important decision I've had to make since 1978 when I decided to get a bikini wax.
-- Arnold Schwarzenegger
Politics is not a bad profession. If you succeed there are many rewards, if you disgrace yourself you can always write a book.
-- Ronald Reagan
"I wrote a book"
--Bill Clinton
Old 07-24-2006, 07:31 PM
i just had four wheel alignment. it seems to only pull hard to right when hard on breaks. and there is like a howling sound it sounds like it is from the left front. today i changed both front calipers and installed new pads. same problem didn't help. anyone ever have rack n pinion go bad. any ideas fellows. going to shop tomorrow have bad tranny fluid leak dreading the results on that one. and need to get this howling noise and break problem fixed. help guys??!!!!!!
