Go Back   Automotive Forums Car Chat > Mazda > 323/Protegé/Familia/Etude/Allegro
Old 07-22-2006, 09:57 AM
ehabw ehabw is offline
Question Cant find the fuel filter
Can anyone tell me where to find the fuel filter on a 2000 protege?
Old 07-22-2006, 01:31 PM
stamar stamar is offline
Re: Cant find the fuel filter
on the 95, its near the drivers side firewall. under the hood.
You know what though, that wont help you at all. lol.
97 sentra gxe auto 174k miles
89 nissan d21 truck z24i 213k miles ( with a cabover camper)
Old 07-23-2006, 03:26 AM
Flash75 Flash75 is offline
AF - Advisor
I don't about the 2000 but the 2002 Protege has the filter built into the fuel pump, the assembly is in the fuel tank. The 02 maintenance schedule doesn't suggest or mention changing the fuel filter unless your car is in Chile where is changed every two years.
Clifton
Old 07-23-2006, 03:22 PM
ya on the 95-98 it is very near the engine, much closer than most cars. so follow the fuel line from the throttle body down below the engine to the firewall. very obscurred by unrelated junk its very small cylinder black in most cases.
I do believe the next model line is 99-2002 and it has no fuel filter.
Old 07-29-2006, 11:01 AM
96AccordLXAnnivEd 96AccordLXAnnivEd is offline
lol...just changed it last month on my 1995 protege. it was located between the engine and the driver's console, about a foot deep within wires. i found it resting on the car body. a very difficult job. took me two hours and misc acrobatics to take it out and fit the new one in
Old 07-29-2006, 06:52 PM
Estlander Estlander is offline
Yep, that's exactly where it is on my 1995 Protege as well, and it indeed looks like hell of a lot work which is why i have not changed mine yet, although would like to.
Old 08-01-2006, 07:21 PM
95supreme's Avatar
95supreme 95supreme is offline
Hello,
from 1998 and up the fuel filter is not replacable. It's built into the gas tank. To replace it would be a huge job and cost alot of money!
According to Mazda, it's a self-cleaning fuel filter that never needs changing.
If you're concerned, get a good fuel injector additive to add to a full tank of gas, and it'll clean out your fuel system. Also, use high octane gas for long road trips.
Old 08-01-2006, 09:26 PM
mnwalleye mnwalleye is offline
There is an earlier post on this very subject I asked myself on the 2000 model year. The fuel filter in in the tank with the fuel pump and is located in the middle of the back seats. Simply lift up the lower part of the seat and you will see the access plate. Find the post that gives specfic instructions on how to remove it safely but doubtful that it needs to done on a regular basis.
Good luck,
MN Walleye
Old 08-20-2006, 01:12 PM
wbholland wbholland is offline
Location of fuel filter on b2600 mazda?
Old 11-02-2006, 08:50 AM
Doug Tatham Doug Tatham is offline
The above posts are mostly right. There is a screen attached to the pump that is part of the pump assembly in the tank. I wouldn't call it self cleaning. There is another filter (I changed mine at 175000 miles - 1999 protege) but it should last the life of the car. You have to remove the throttle body, intake hoses and a lot of stuff just to get to it. It's mounted to the body on the drivers side close to the firewall. I followed the fuel lines. Unless you get some really bad gas, it shouldn't require replacement. Use some sea foam injector cleaner.
