Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 07-21-2006, 11:54 PM
AbsoluteGTR's Avatar
AbsoluteGTR AbsoluteGTR is offline
Send a message via AIM to AbsoluteGTR Send a message via MSN to AbsoluteGTR
Need help asap with boost leak tester
Okay, I am trying right now to find out if I have a boost leak. i have made the contraption and whatever, and have already attached it to the turbo and I am using a regular hand pump/ bicycle tire pump. So I am pumping away, and it as if I am getting nowwhere. I assume I have to pump the ai through the whole system first before I can hear an air leak, but for how long must I pump it feel like I have been pumping forever.
Any input? Does it sound like I am doing anything wrong?
Thanks
Old 07-22-2006, 12:27 AM
crunchymilk55's Avatar
crunchymilk55 crunchymilk55 is offline
Send a message via AIM to crunchymilk55
Re: Need help asap with boost leak tester
can't use a bike bump, in fact most of the 12volt car pumps don't even work. Best bet is to get it to a gas station and use that, or find someone with an air compressor
now - 2000 civic
soon - 2002 is300
Old 07-22-2006, 12:41 AM
george536's Avatar
george536 george536 is offline
lol, i tried the 12volt in car one, that sucked too. you need a real compressor, i used the one at my work, but dont overboost.
-1997 Eclipse Spyder GST |Stock|
-1990 Eclipse GSX
|ACL Main & Rod Race Bearings|Balance Shafts Removed|ARP Head Studs|Cometic HG|FP 20g TDO6H|EPROM Chipped (stutter box 5k, fuel comp.)|PTE 680cc inj.|Walbro 255 HP Fuel Pump|Autoteq FPR|SAFC 2|FMIC|2g MAF|Dejon Tool Hard Pipe|Greddy Type S|MBC at 17PSI|Ported 2g Exhaust Manifold|02 Housing w/ Tial 38mm WG|Full 3inch Exhaust w/ Y-pipe Cutout|Fidanza Flywheel|ACT 2100|4 Bolt LSD Rear|Poly Mounts|KYB AGX Suspension|Roll Bar|
Old 07-22-2006, 01:12 AM
LOL, I gave up on the bike pump after 10 mintues of sweating like a bitch, then I decided to gerry-rig the 12-volt car pump so that I can plug it into the wall....how can this NOT work? Or will it just take forever?
The previous owner said the leak is where the throttle body flap's center arm meets the edges of the throttle body....he said the two rubbr o-rings are either gone or cracked...he said that is where it is leaking from...is that a common place for air to leak from?
I am searching the hell out of tuners, but no luck....
Old 07-22-2006, 02:15 AM
haha sorry but I just had a mental image of someone going at it with a bike bump, sorry man that had to suck. I dont know if the vfaq still says it, but it used to say you could use a bike pump. BULLSHIT, lol.
Ok, yeah that's a common boost leak spot, as is most of the fucking throttle body. There are so many places it leaks from, and in my case, leaks from most of them!
now - 2000 civic
soon - 2002 is300
Old 07-22-2006, 02:33 AM
Thor06's Avatar
Thor06 Thor06 is offline
Jizzed In My Pants
Actually, when it was running well, I had no boost leaks at all.
Build on hold until I get a good paying job, either in school or once I get out. At that time a full tear down and complete rebuild should be in order.
The Purple People Eater will ride again... January 2011 can't come soon enough.
Old 07-22-2006, 02:44 AM
that's a first. Tested to 20psi and all? We almost always have 1 or more small ones.
now - 2000 civic
soon - 2002 is300
Old 07-22-2006, 10:56 AM
Also when doing this I can feel air throught the breather hose.
When doing this, am I supposed to fully close the throttle plate (taking off the cable)?
Old 07-22-2006, 06:28 PM
.............any help?
Old 07-22-2006, 08:52 PM
4g63gst20 4g63gst20 is offline
Send a message via MSN to 4g63gst20
i i use one this little tanks that they sell at menard/walmart, it holds 125, 5 gal, and it sounds like a boost leak on the TB, but only if the butterfly is closed, if i open it the noise is gone.
-MODS-
Autometer Boost,Oil Presure,And Water Temperature Gauges./Geddy Turbo Tmer/Eibach Sportline Springs Matched With Adjustable Iluminas 4 Corners/Konig 18" On Nitto Extreme 555/ACT 2100 PP with Street Disc/Extended Push Rod/Urethane Motor Mounts/XS Power FMIC. 28X10.5X3.5/Greedy Type RS BOV/ evo3 16g Turbo/MBC At 18PSI/Bian Crower 272 cams/SAFC2 With 510cc Injectors/Walbro 190 FP/
1/4 mile=14.3@103MPH
Old 07-22-2006, 10:26 PM
Okay can suomeone give me full directions on how to perform a boost leak test? I have searched my ass sore for instructions on vfaq, thsi forum and tuners but cannot seem to find any. Am I fool? I seriously cannot get it to work...is it only because i am still using the 12 volt air compressor?
I am going to go to walmart tomorrow, but until then can someone PLEASE post up directions or a link to them. This is aggravating me, for some reason...lol.
