Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 07-21-2006, 08:04 PM
Eclipse4ever's Avatar
Eclipse4ever Eclipse4ever is offline
Quick question
Hey guys, I have seen around those Cyclone manifold intake. People put em on and take out their stock ones. Whats the gain from it if any? And what cars are they out of 1st gen? I wanted to get one for the GSx, are they direct bolt on from the stock one or do I need some fabricating.
Thanks
1997 Eclipse GSX
Old 07-21-2006, 08:35 PM
NOFX0617's Avatar
NOFX0617 NOFX0617 is offline
Send a message via AIM to NOFX0617
Re: Quick question
From what I understand you can just put the intake manifold on there but it wont work correctly so you might actually lose power...you have to install a few other parts for it...not sure what they are but I remember there was a good write up on DSMtuners about it a little while back....
1998 Eclipse GSX
6 Bolt swap
MHI Big 16g
FP Race Manifold
Apex'i N1 Cat-back
Apex'i N1 Downpipe
Walbro 255 fuel pump
GReddy Type S BOV
Turbo XS Boost Controller
Balance Shaft Elimininator
ACT 2600
RRE 11lb No Name Flywheel
Prothane Motor Mounts
Tokico Illuminas Advanced Handling Kit
RRE Front and Rear strut tower bars
RMDSM Front and Rear Sway Bars
TRE Stage 2 Tranny
ARP Head Studs, Main Studs, Rod bolts
Old 07-21-2006, 09:19 PM
Blackcrow64's Avatar
Blackcrow64 Blackcrow64 is offline
Re: Quick question
It just has an acuator that connects to a vacuum line which controls which runners it opens. It has short ones and long ones on them. I believe they are a direct bolt on for 6 bolts but will not fit a 7 bolt unless you have the head ported to match. I am considering getting one real cheap on ebay for my 6 bolt.
-Brian
  • 92 Firebird sold
  • 97 Talon TSI AWD sold
  • 05 Cobalt LS sold
  • 02 Tahoe LT sold
  • 06 Cadillac STS4 AWD sold
  • 03 Corvette Z06 sold
  • 14 Silverado 1500
  • 26 Equinox RS
Old 07-21-2006, 10:56 PM
crunchymilk55's Avatar
crunchymilk55 crunchymilk55 is offline
Send a message via AIM to crunchymilk55
Re: Quick question
not worth the effort. A magnus or any other smim would outflow it easily.
now - 2000 civic
soon - 2002 is300
Old 07-21-2006, 11:11 PM
SLoe's Avatar
SLoe SLoe is offline
Re: Quick question
I actually asked this question when I first started posting too. If you search, there are at least :15millionsign: threads about it IIRC.
96 GST 5 spd.......(R.I.P.) smashed by a fallen tree
2001 Camaro SS 6 speed goodness!
Old 07-22-2006, 09:45 AM
kjewer1 kjewer1 is offline
AF - Advisor
Re: Quick question
This defeats the entire purpose of the cyclone manifold though It is not at all designed for high flow. The benefit is that it actually flows less under vacuum, increasing low and midrange torque. For 99% of DSMers power is the main concern, and for those poeple a SMIM makes more sense, or even just a stock 1g piece which does pretty well.
If someone is really that interested in low end torque they're running the wrong motor IMO, get a diesel. For those that want to try the cyclone manifold anyway, be aware that there is a whole seperate subsystem that includes an ECU that knows how to properly control the manifold's vacuum system for the switchover. You can make it work with pressure switches and other such fuckery, but it takes some doing. There is a ton of info out there about this, most of it wrong, but out there none the less.
Edit> Descriptive titles please! "Quick Question" says absolutely nothing about what is in the thread.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 07-22-2006, 10:00 AM
SLoe's Avatar
Re: Quick question
Yeah, I wouldn't have clicked this one if it was titled "cyclone manifold question"
Old 07-22-2006, 01:16 PM
Killa_DSM's Avatar
Killa_DSM Killa_DSM is offline
Re: Quick question
Here is a link that will show you how to install one..
http://www.dsmtuner.com/forums/showthread.php?t=224551
"Life begins at 20psi"
97 Eclipse GST-X 5spd
PTE 5031e/pte 880cc/vr4 fuel pump/Devils Own Water injection 12gph nozzle/pre turbo meth injection/fmic 28x10.5x3.5/greddy type-s bov/12" K&N/FP intake/dsmlink/gm 3.3 bar/maft/blitz ebc/act 2600/act 6 puck/SS Clutch line/3" turboback.
