| Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible. |
poor idle
I have a 1995 Eclipse that when it is cold it will idle fine. Then when it starts to warm up it will start to mis-fire. As soon as you increase the engine speed the mis-fire goes away. The car had problem code for the EGR valve and so that was replace and cleared up that problem. It had new NGK plugs installed.
Any help would be great |
Re: poor idle
Did you check your plug wires too?
Also you should put your model eclipse in your signature along with any mods just for help referance and welcome to AF
1998 Eclipse GSX 6 Bolt swap MHI Big 16g FP Race Manifold Apex'i N1 Cat-back Apex'i N1 Downpipe Walbro 255 fuel pump GReddy Type S BOV Turbo XS Boost Controller Balance Shaft Elimininator ACT 2600 RRE 11lb No Name Flywheel Prothane Motor Mounts Tokico Illuminas Advanced Handling Kit RRE Front and Rear strut tower bars RMDSM Front and Rear Sway Bars TRE Stage 2 Tranny ARP Head Studs, Main Studs, Rod bolts |
Re: poor idle
what did you gap your plugs?
FP 18g turbo e3 o2 & mani, 3" exhaust, , 7 bolt, wiseco/eagle, walbro 255hp re-wired, Aeromotive FPR, FIC 1150cc, injen intake, greddy RS, aem wideband, turbo xs mbc, act 2600 clutch sprung 6 puck, BC 272's, dsmlink v2.5, ETS FMIC, Devils Own, JMF SMIM. 18 Inch chrome rims In closet AEM Fuel Rail, SS Lines, 1997 TSI AWD Diamonds Are 4Ever 12.7 @ 107 http://i83.photobucket.com/albums/j2...y/DSC00461.jpg |
Re: poor idle
I gaped the plugs at .48
Re: poor idle
search...
now - 2000 civic soon - 2002 is300
Re: poor idle
One more thing to add is that the timing belt was replaced 5000 miles ago and it did not seem to idle rough then.
1995 Eclipse GS w/2.0 5-speed |
Re: poor idle
Black 92(6 bolt) Eclipse Auto N/T 2.0 K & N Air Filter, Megan Racing Strut Bars, 2.25 Mandrel Bent Catback, Unorthodox crank pulley, EGR block off plate, No balance shafts, KYB AGX struts and shocks, two piston GSX calipers 1990 AWD Astro Van Don't mod a car with problems. Don't swap parts without testing them.
Re: poor idle
Just to add to the information. When you put load on the engine such as the turning on the the A/C the idle smooths out
Re: poor idle
Ngks should be gapped at .028 but thats for turbos :S. Still I don't thinkg it should be at .48
If you search "plug gap" in the performance section you will find the thread on that one.
Re: poor idle
Factory gap on a 2gnt is .44 Have you checked for a vacuum leak?
