Go Back   Automotive Forums Car Chat > Oldsmobile > Bravada
Closed Thread Show Printable Version Show Printable Version | Subscription Subscribe to this Thread
Old 07-21-2006, 12:58 PM
therealcruiser therealcruiser is offline
climate control blend door problem [Solved]
can hear blend door opening and closing all the time just had in for new front hubs with bearings and abs replaced now a/c and heat keeps cycling out vents. i can control what vents it comes out but keeps blowing heat then ac can hear door moving back and forth any suggestions
Old 07-22-2006, 09:31 PM
Chris Stewart's Avatar
Chris Stewart Chris Stewart is offline
AF - Advisor
Re: climate control blend door problem
You might try treating it like a computer...reboot. Disconnect the battery for 20 minutes and make sure the cell phone charger doesn't have a cell phone in it.
Surprisingly enough, there was a guy years ago on the old Wrenchead.com site who couldn't reset the codes on an OBDI vehicle and later found a cell phone on the charger which was back feeding the ECM enough the codes wouldn't reset.
Old 07-23-2006, 06:53 AM
thanks for the reply chris, i disconnected the battery overnight and reconnected still the same. no accessory's plugged in ...blend door just keeps going back and forth. ?? i have to ASSUME the blend motor actuator works if it opens and closes ? was able to disconnect electrical connection at acctuator and it defaulted to the middle. can the computer be reprogrammed or???
Old 07-24-2006, 02:36 AM
AF - Advisor
Here's some info.
Big thanks to riccbhard and JoshBarber at the Blazer site.
http://www.automotiveforums.com/vbul...ght=blend+door
Old 07-24-2006, 10:12 PM
ok just fixed this problem ..blend door was going back and forth searching for right spot to match temperature... moved temp knob back and forth several times then moved temp very slow on all differebt settings and it hit now working. thanks to everyones input
Old 07-25-2006, 06:01 AM
AF - Advisor
Good work, we'll try to remember your fix.
Old 01-12-2007, 09:07 AM
herbravada herbravada is offline
Re: climate control blend door problem [Solved]
Our Bravada seems to be having this problem, but having read in several posts about the blend door motor being behind the glove box - I cannot find it. Ours is a 2000 Bravada - is it in a different location on the 2000?
Anyone got pictures of it in place?
Old 01-12-2007, 11:09 AM
following up - I looked again and I can see the two vacuum servos which control the outside air and the outlets. They both work so I know I have vacuum, and they direct the air correctly but no matter what I do I get hot air, so I am suspecting the blend door motor, but cannot see it. I found a picture here of the unit itself but only after removal. All the descriptions I have found says flip down the glove box door and there it is. I see the flasher, a large wiring harness connection, the two vacuum servos and that is about it. It has the automatic climate control if that matters.
Old 01-27-2007, 04:40 PM
Question Re: climate control blend door problem [Solved]
I am wondering if anyone reads these posts?
Ok I have found the actuator, managed to remove it (only a half dozen bloody spots on my hands from squeezing hands into where they were obviously not intended to go), disassembled it and found a small crack in the large plasit gear but it was not acutually broken.
I connected it to the wiring connector and it turned on and ran slowly - once. There after it did not move except for about one second bursts and at no specific time.
I back probed the connector with the switch on and got 12+ on the brown wire as I expected after finding a wiring diagram on here. The return wire from the pot inside (forgot the color code but maybe was the light blue) would go from 0 to about 5 volts depending on the position of the large gear.
Before spending the $100 or so to replace it - is there anyone with any other testing I can do to verify that it is really this actuator that is the problem?
Old 01-27-2007, 07:24 PM
ericn1300's Avatar
ericn1300 ericn1300 is offline
AF Premium User
Maybe if you started a new thread about your problem you migh get more responces. this one is titled "solved"
Old 01-27-2007, 10:25 PM
ZL1power69's Avatar
ZL1power69 ZL1power69 is offline
GM S-Series Mod
yes, this thread is over 6 months old. a new thread can be started if need be.
2000 Chevy Blazer ZR2
Performance Mods: Numerous
Suspension Mods: Some, but not enough
Exterior Mods: Just Right
1987 Buick Turbo T Dark Red
Low 11 sec sleeper
.030 4.1 block, PT6262E, & other odds and ends....
My Cardomain
Closed Thread
