Go Back   Automotive Forums Car Chat > Honda > Let's get Technical!
Let's get Technical! Discussion for hardcore in-depth motor heads!
Old 07-21-2006, 09:11 AM
hvcar hvcar is offline
Engine goes off from time to time?
Hi,
I have a Honda Accord LX 1995. Since a few day ago, when I drive it at low speed (< 15mph) or stop at the red trafic light, the engine goes off many times, especially when A/C is on. If I drive it at more than 20mph and don't break, then it is okay so far. Can somebody give me some help?
Thanks!
Harvey
Old 07-21-2006, 11:43 AM
somick's Avatar
somick somick is offline
Re: Engine goes off from time to time?
Welcome to the board!
What about the regular maintenance? Spark plugs, distriburor cap, wires? Has it been done?
Sam
Originally Posted by RIP
Please post back when you fix it so we all will learn something
Old 07-21-2006, 11:59 AM
00accord44's Avatar
00accord44 00accord44 is offline
High on Potenuse
Send a message via AIM to 00accord44 Send a message via MSN to 00accord44 Send a message via Yahoo to 00accord44
You said this happens when below 15mph, but is that under acceleration, decel, or both? You may just need to adjust your idle screw, but it could be a number of things. Fuel filter, fuel pump, etc. No other malfunctions happening that might be in conjunction with the idle/fuel?
ECNATSISER AL AVIV
Old 07-21-2006, 12:14 PM
I did regular maintenance at dealer. The most recent one was done on June 24, 2006 -- 96000 miles (I don't remember exactly), and was told that every thing was good.
It happens both when I acce and decce, also when I move backwards, when I stop at the red light. The car "shakes" (vibrates) more strongly at those times, then sometimes stops. But, no other signal, e.g. the "Engine" light on the panel is not on at any time.
Thanks!
Harvey
Old 07-21-2006, 07:00 PM
somick's Avatar
How about vacuum leak?
Check all your vacuum hoses.
Sam
Old 07-24-2006, 09:39 AM
Sam
Thanks. But, how to check the vacuum leak, if any?
Harvey
Old 07-27-2006, 04:23 AM
Vti-R_integra_1994 Vti-R_integra_1994 is offline
Originally Posted by hvcar
Hi,
Thanks!
Harvey
i have similar problem, but mine is just when starting the car the engine dies out, once the car gets moving it will stay on
Old 07-27-2006, 01:11 PM
somick's Avatar
Harvey
Inspect them visually and physically: no cracked or broken parts. If that fails, spray some carburetor cleaner, WD-40 or other flamabel fluid. If the RPM increase: you found the problem.
Be very carefull: the hot engine may catch fire!!!
I have heard people sprayed just regular water, but never done it myself.
Good luck!
Sam
Old 08-15-2006, 11:42 PM
Jenn1978 Jenn1978 is offline
Hi i also have an 89 accord lxi and when i go to start it the engin dies out , new plugs & wiers and new fuel filter , is their another fuel filter ????? plz help
Old 08-16-2006, 02:21 AM
hondacivic99sivtec's Avatar
hondacivic99sivtec hondacivic99sivtec is offline
Send a message via Yahoo to hondacivic99sivtec
there is a in tank fuel filter. another way to check for vaccum leaks without a fire(lol), is to use soapy water. then look for the bubbles and then just rinse, fix the hose.
-tony-
2000 honda s2000
Old 08-16-2006, 09:39 AM
cphilip-dot-com cphilip-dot-com is offline
How do you figure something that is a Vaccum is going to cause bubbles? Its sucking it in...
