Old 07-21-2006, 08:09 AM
Moe Arif Moe Arif is offline
89CivicDX-Too much oil
My mechanic put too much oil during oil/filter change maintenance. Dip stick checks about 1 cm. more oil level beyond the max. dot on the dip stick.
Assuming that too much oil is also not good, how do I remove some oil from the pan, without opening the oil drain cork (Ya Ya I know)?
Old 07-21-2006, 12:13 PM
thefooshmeister thefooshmeister is offline
Send a message via AIM to thefooshmeister
Re: 89CivicDX-Too much oil
youre gonna have to just jack the car up and drain some oil from the pan, not that hard should only take you few minutes or two. id use a ratchet wrech if you can because the oil pan bolt is uneven and likes to get stripped easily.
98 Jetta GLX VR6-vroom vroom!!
91 CRX Si-R..busted..
Old 07-21-2006, 02:05 PM
2poor2tune's Avatar
2poor2tune 2poor2tune is offline
Send a message via AIM to 2poor2tune
hey you could always put the dipstick in and clean if off about 1000 times. but seriously just do the pan adea. losen it untill it slowly drips from the hole with the bolt still in and check it when you think it should be there. good luck
Old 07-21-2006, 05:50 PM
Hybrid1990crx's Avatar
dude i seriously wouldnt worry about it being 1cm too full.
Old 07-21-2006, 11:19 PM
FrodoGT's Avatar
FrodoGT FrodoGT is offline
Nah, mine was a little full too, not a big deal..just dont go TOO full, if your crank dips into that oil your going to have alot of issues with seals and also stress on the engine from the increase in drag, but that is an extreme case..your fine.
Cheap, Fast, Reliable..Pick two
Current project:
Rio Red 91 hatch.
A6/Z6 build, Hondata S300, Tokico illumina/Ground Control.
"I'd rather run 12's on steelies than 15's on rotas."
Old 07-22-2006, 09:07 PM
Hey fellow brothers - I did it. Taped two straws (thick ones that would just slide into where the dip stick goes in) together to make into one long flexible tube. Took the dip stick out. Inserted the "straw tube" into the hole, deep enough, sucked the oil with mouth until I saw the oil coming close to the mouth. Pinched the tube, took it out and drained.
Took me about 20 times inside and then out to drain. You'l be amazed at how much oil came out.
I was able to bring the oil just to the proper max mark.
I did not want to to do it from the drain cork cause they put after market cork that my friend mechanic seals it with a putty, everytime an oil change is done, and I did not want to do it.
Old 07-22-2006, 09:33 PM
now thats what i call desperation lol good job mcguyver
Old 07-23-2006, 12:37 AM
FrodoGT's Avatar
I was just about to use a mcguyver reference too...
Current project:
Rio Red 91 hatch.
Old 07-23-2006, 06:31 AM
ATMDC's Avatar
ATMDC ATMDC is offline
lol, at least it worked i guess, i could picture driving by seeing someone sucking oil out with their mouths
Old 07-23-2006, 12:17 PM
this is what happens when you teach a monkey how to open his hood.
