Old 07-20-2006, 11:32 PM
TTL_DNS TTL_DNS is offline
Dash shaking when fan is on
ok here a question for you all i have a 94 PA that i just got and when the fan is turned on for both heat and air when the fan is on past 2 bars the whole dash starts to shake is it my blower motor goin bad if so where is it and how much and how hard is it to replace if its not that then could someone tell me what it is
Old 07-21-2006, 08:08 AM
HotZ28's Avatar
HotZ28 HotZ28 is offline
AF Moderator Elite
Wink Re: Dash shaking when fan is on
It sounds like the blower bearings are shot! The blower is located under the hood, on the firewall. It helps to remove the strut brace for easier access. Cost about 40 bucks at O'Reilly Auto Parts or Advance Auto Parts
With the right tools, it takes no more than 1/2 hr to change and that includes a 10 min break!
Old 07-21-2006, 10:30 AM
kok328 kok328 is offline
Job should require less than a 6 pack to complete.
Old 07-21-2006, 10:37 AM
aarcuda aarcuda is offline
if its anything like mine, the little plastic shroud around the blower moter will crumble into little pieces when you try to remove it. save the pices that have the holes for the bolts to go thru. you'll have to reuse those because they space out the bolts (or get some thick washers)
Old 07-21-2006, 06:39 PM
Talking Re: Dash shaking when fan is on
thanks yall i found the parts through murray's and got a discount from my gramps and my friends dads shop is installing it for about 60 bucks so total is around 105 bucks pretty good....
Old 08-01-2006, 06:37 PM
DioGreer DioGreer is offline
I replaced one on an 86 olds cutlass once. It was even easier than the PA would be. The cutlass blower is on the passenger side right near the hood support lever/spring. That was a no beer job
although beer was consumed shortly thereafter
