Go Back   Automotive Forums Car Chat > Chevrolet > Impala | Impala SS
Old 07-20-2006, 06:35 PM
Stubin Stubin is offline
2002 Coolant sensor Location
Hi all,
Sorry if this has been asked before but I couldn't find an answer...
I'm looking for the coolant sensor location on a 2002 Chev Impala LS 3.8. I belive that the sensor is bad because the low coolant light is coming on when both the Rad and the Resevoir are full. Any help is appreciated! (or possible solutions )
TIA
Stew
Old 07-20-2006, 07:00 PM
maxwedge maxwedge is offline
A990 racer
Re: 2002 Coolant sensor Location
Originally Posted by Stubin
Hi all,
TIA
Stew
welcome to AF. It should be in the r/s radiator tank, I believe.
Old 07-20-2006, 07:15 PM
bigrod118's Avatar
bigrod118 bigrod118 is offline
R/S radiator tank???
Do you mean the coolant resevoir?
It's actually on the radiator itself.
Passenger side, on the edge/corner of the radiator, about 1/3 of the way down, "back" side, it's grey.
It's basically right in front of your batteries positive post.
Old 07-20-2006, 07:30 PM
A990 racer
Cool Re: 2002 Coolant sensor Location
Yup that's what I was pointing too, not enough detail though, by this time my fingers are stiff from work. Thanks Bigrod for the clearer description, see I typed more this way anyway!!
Old 07-21-2006, 12:11 PM
Gems Gems is offline
A low coolant light could also be a stuck thermostat... If it's stuck open you could get a light... I just had this happen... Changed out the thermostat and now the warning light does not come on... On the 3.8L engine you can replace the thermostat in about 10 minutes...
Go Mark Martin!
Old 07-21-2006, 06:20 PM
But..... If your problem is truly the coolant level sensor there is an excellent "How To" at: www.impalahq.com
Go into the How To" section and you will see exactly what you need to know about changing the sensor...
Go Mark Martin!
