Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 07-20-2006, 06:19 PM
capriceowns capriceowns is offline
Rough day
Well it started out with draining the coolant out of my radiator, but the weld aroud the pet cock broke, so I pulled the radiator, and one of my trans cooler lines fitting spins inside the radiator, so i cut the line.
Then i went to take the thermostat housing off, was leaking from the gasket(the whole reason for my adeventure) I broke some vaccum plunger sensor off, idk what it is yet, and both bolt heads broke off that hold the housing on!
Gragh! My caprice is lucky I can fix this.
Just a good day I guess
only problem is getting the broken bolts out the holes. ever have one of these days? lol
Old 07-20-2006, 06:30 PM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
Re: Rough day
You think you have it bad with your car ... well let me tell you.
Three weeks ago my car decided to kill its own transmission - accumulator spring broke, leading to a sun shell failure - then the water pump completely went south (losing a gallon of water every 45 seconds, and not even through the weep holes), then the transmission shifter knob broke off in my hand (both happened last Friday), now the power steering pump buzzes and as of today the ignition key is stuck in the cylinder, which turns with massive force. Top THAT!
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness!
1967 El Camino L79/M20 old school asphalt raper
Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have.
Old 07-20-2006, 06:33 PM
Re: Rough day
XD I'll get right on that!
Old 07-20-2006, 07:42 PM
1986Z28's Avatar
1986Z28 1986Z28 is offline
Has a Camaro
Send a message via MSN to 1986Z28
Re: Rough day
lol, my car is working fine... knock on wood
Formerly Blownalcoholboy
1986 Z28, 400ci SBC, Twin borg warner billet S467 turbos, Reid case powerglide, Moser 9". Holley EFI, Boost Leash. 950RWHP on pump gas, 1200rwhp on race gas (22 psi)
Best ET 1/4: 8.35 @ 170mph (275 drag radial)
Best ET 1/8: 5.44 @ 132mph (275 drag radial)
Best 60': 1.31 on the back tires (275 drag radial)
AF User Rules/Guidelines
http://www.automotiveforums.com/vbul...uidelines.html
Old 07-20-2006, 08:20 PM
silicon212's Avatar
Confoundingly Lucid
Re: Rough day
Well, I got the key out of the cylinder, but now you can start the car without the key. I just have to get the motivation to go out and install this new lock cylinder I got today.
Old 07-20-2006, 09:38 PM
HLandin's Avatar
HLandin HLandin is offline
Re: Rough day
Speaking of worn ignition, chew on this:
To start my white boxy, I needed the key (would not work without), but, after starting, I could remove the key from the ignition and the car would continue to run (pull the key out in the run position effortlessly). Still, the car would not START without the key in the ignition.
Old 07-21-2006, 08:40 AM
GreyGoose006 GreyGoose006 is offline
Re: Rough day
my dads old s-10 does this, but it is so bad that if you dont do the lock thing after you take the key out (you know, the lock switch all standard trans cars have), you can then start the thing with no key. if you do the lock thing, you need the key.
Old 07-21-2006, 12:16 PM
Blue Bowtie's Avatar
Registered Offender
Re: Rough day
You think you have it bad with your car ... well let me tell you...(Yada, yada...) Top THAT!
O.K. I used to have a Chrysler - 'Nuff said? Top THAT!
Oh, wait... You said "car" - Never mind.
Old 07-21-2006, 12:56 PM
broughy84's Avatar
broughy84 broughy84 is offline
Re: Rough day
My 88 silverado does that. You don't need the key to start it even if you do turn it back to lock. you can also turn it to accesory without the key....I actually kind like it.
Matthew Brough
1997 Geo Prizm -- 301,000 miles
2000 Honda Accord -- 225,000 miles
2004 GMC Yukon XL -- 223,000 miles
1987 Jeep Comanche -- 116,000 miles
Old 07-21-2006, 11:14 PM
1986Z28's Avatar
Has a Camaro
Re: Rough day
mine also does that, bewarer though, it wont be long before you can start it without the key, keep an eye on it
Old 07-22-2006, 12:18 PM
Registered Offender
Re: Rough day
So, AlkyBoy - Where is it you live again? I may be in the market for a used-but-nice vehicle soon...
Old 07-27-2006, 01:51 PM
bobss396's Avatar
bobss396 bobss396 is offline
Send a message via AIM to bobss396
Re: Rough day
I had the ignition cylinder seize up on my '79 wagon, glad i had a big pair of pliers to turn it to get home.
My '84 wagon had the key bust off in it last year and I could start it without the key, I made sure I locked it when it was parked. I ran it a few months and finally splurged $15 and changed the cylinder.
Bob
Old 08-16-2006, 09:30 AM
PeteA216's Avatar
PeteA216 PeteA216 is offline
Send a message via AIM to PeteA216
Re: Rough day
My 84 caprice does the same thing, but when I had a new set of keys made, it didn't do it with the new set until I ground down the last tooth on the tip of the key. I did that intentionally because I liked how the old set came out. I could start my car, take out the keys, lock the doors, and go inside while the car warmed up in the winter.
