Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 07-20-2006, 04:30 PM
Digitaleuphoria Digitaleuphoria is offline
Lose wheel studs?
Alright, I can't find this using the search so I'm making a thread to ask for any insight before I go try to figure it out on my own tomorrow.
The other day I was driving around and I heard this loud clunking sound. When I got home I couldnt find anything lose under the car so I figured I'd check the wheels since the sound seemed to be comming near the rear passenger one. I took off the rear passenger wheel and the studs move back and forth a bit. They only move 2 to 3 millimeter's I'd guess in either direction. The drivers side studs don't move so I'm guessing the fact that the passenger side moves is a bad thing.
If you move one stud, they all move together so its not the studs themselves. Have I lost you yet? Anyway, I hope you understand, any ideas what it could be? And do you think that could be causing the loud clunking sound I'm hearing even tho it only moves a tiny bit?
2000 Pontiac Grand Prix GTP
Old 07-20-2006, 04:35 PM
corning_d3 corning_d3 is offline
Send a message via Yahoo to corning_d3
Re: Lose wheel studs?
Wheel bearing, maybe?
2007 Certified DaimlerChrysler Service Technician...
True blue GM at heart.
Old 07-20-2006, 04:39 PM
If it is a wheel bearing, how dangerous would it be to drive? Sorry if that's a stupid question, still new to everything.
I'm hoping its just something loose as I cant afford any new parts for around another week or so. Hopefully I can avoid walking to work
Old 07-20-2006, 04:53 PM
If it just started making noise, you could get a month out of it, maybe more depending on your driving habits. Since it's a FWD, there's less stress on the rear bearings, so thats a plus. But most are only sold as an expensive assembly.
When you where checking the studs, did the plate they were pressed in wiggle around? I assumed it was by the description..
Old 07-20-2006, 04:56 PM
I'm not sure if the plate moves around, I didnt take the drum off, I just moved the studs with the drum still on. Havn't had the time to investigate it fully, later tonight or tomorrow I plan on lookin further into the problem.
Old 07-21-2006, 11:45 AM
gthompson97's Avatar
gthompson97 gthompson97 is offline
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
Did the drum and everything move when you moved the studs? The whole hub should actually move if the wheel bearing is out. If it is bad, I wouldn't drive it unless you have to and when you do, don't beat on it. Driving on a bad wheel bearing is not a good idea.
95 Talon TSI AWD
97 Eclipse GST
Old 07-21-2006, 01:09 PM
No, the drum didnt budge. I think I have it figured out. I looked at the wheel closely, its not butted up against the drum all the way like the other 3 wheels are. I have a feeling that when I torqued the lug nuts down, it pulled the plate that the studs are attached to and either broke something or loosened something up. I'm heading out RIGHT NOW to check it out I'll post back if I fix it or not, wish me luck.
Old 07-21-2006, 01:36 PM
$10 says something in the hub assembly is fucked up so you might as well just replace it anyways before something bad happens.
95 Talon TSI AWD
97 Eclipse GST
Old 07-21-2006, 03:12 PM
Ok, its all fixed now. It was nothing serious. The problem was my own stupidity and lack of attention to details. I'll start from the beginning.
My car had aftermarket wheels on. I hit a pothole the other day, which blew my tire out and dented my new wheels *RIP wheels *. I can't afford to buy a new replacement wheel and tire just yet so I put the old wheels back on until I got a bit more money. Well, when taking the wheels off, I forgot about the little plastic spacers that went on with them, they were stuck to the car preventing the old wheels from sitting propery. Well, when I torqued the old wheels on, they pulled the plate that has the wheel studs on them which pulled the drum out a bit. After I stared at the hub assembly awhile I finally noticed those spacers were still on there, so I pulled those off, put the drum back on right, and the old wheels finally sit flush up against the drum the way they should. Now the wheel studs don't move anymore and there is no more clunking sound eminating from the back.
Sorry If I wasted your time with such a problem.
Moral of the story: Pay attention to what your doing!
Old 07-21-2006, 05:36 PM
SLoe's Avatar
SLoe SLoe is offline
Now about that $10.......
96 GST 5 spd.......(R.I.P.) smashed by a fallen tree
2001 Camaro SS 6 speed goodness!
Old 07-26-2006, 01:47 AM
We never shook.
95 Talon TSI AWD
97 Eclipse GST
Old 07-26-2006, 07:00 AM
SLoe's Avatar
Damn!!
