Old 07-20-2006, 03:24 PM
greywolf0425 greywolf0425 is offline
Send a message via MSN to greywolf0425 Send a message via Yahoo to greywolf0425
1998 S10 Issues
Have a few issues I am hoping someone can help shed some light on:
1. My A/C is no longer blowing cold air. Also when attempting to use my defroster i am getting nothing but fog on my windshield.
2. A recurring problem is also that the accelerator seems to stick going down the road, even when it is out of gear the engine is revving high.
3. I am getting a lot of heat blowing down on my feet while driving. If i turn on the vent it cools down some.
Thanks for any help offered.
Old 07-20-2006, 03:49 PM
corning_d3 corning_d3 is offline
Send a message via Yahoo to corning_d3
Re: 1998 S10 Issues
Have you had the system pressures checked? It could be just low of freon, or a bad clutch coil.. If you turn the A/C switch to off, does it idle back down?
2007 Certified DaimlerChrysler Service Technician...
True blue GM at heart.
Old 07-20-2006, 05:24 PM
rlith's Avatar
rlith rlith is offline
Send a message via AIM to rlith Send a message via MSN to rlith
Re: 1998 S10 Issues
Have your ac system checked for leaks
When you get the moisture on your windshield, does it smell sweet? (Turn on the heat to verify this)
For the hot air on your feet, open the glove box and push small metal clip up and lower glove box and remove the gray vacuum line...you will hear air push out...stop it up with a vacuum cap and your all set...
people call it a "hot foot fix"
Old 07-20-2006, 07:28 PM
Re: 1998 S10 Issues
Have not had the system pressures checked yet. I will try the hot foot fix. And yes there is a sweet smell when i turn it on.
Old 07-20-2006, 08:00 PM
rlith's Avatar
Re: 1998 S10 Issues
The sweet smell is your heater core taking a dump... If it's leaking enough to mist the windshield, you need to replace it before you end up with more antifreeze on your passenger side carpet..
