Old 07-20-2006, 12:47 PM
boilerman boilerman is offline
Question 2003 P1406 code
We have a 2003 Windstar/3.8L v6/auto and the check engine light came on. The only code that came up was the P1406 (Differential Pressure Feedback Electronic Sensor circuit Downstream Hose). Any ideas or help on how to tackle this?
Old 08-28-2006, 06:56 AM
Re: 2003 P1406 code
Looked around but still can't seem to track this down. Any help?
Old 08-28-2006, 07:41 AM
busboy4 busboy4 is offline
Re: 2003 P1406 code
Hi
I am assuming you are not at all familiar with DPFE. Forgive me if I am wrong. I looked online at an '03 winnie, and from the picture your DPFE (Differential Pressure Feedback EGR , I think) sensor looks to be attached to the front left (drivers side) of the intake manifold, just above and to the right of the oil dipstick. It is clearly visible in the photo where described, about 11/2" X 31/2" in size with an electrical plug, and two hoses coming off of the bottom. Cannot tell you which is the upstream/downstream hose, but I'll wager you find one disconnected, broken off, cracked or otherwise open. In any case many of us have replaced our DPFE's on various model years due to failures and engine codes. Unless you find an obviously damaged hose, with an otherwise intact DPFE, you will probably want to replace the sensor. It should run around $50, and if you buy at autozone or similar, it may be called the EGR valve position sensor as that is its function.
If you search the forum for DPFE you will see many other posts. I have not dealt with your exact code, but have dealt with a similar 1400's code that pointed to a disconnected (broken off actually) hose on the DPFE. In other words, the code pointed dead on to the problem. I am hoping the same in your case.
Best of Luck
Old 08-28-2006, 03:46 PM
rodeo02 rodeo02 is offline
Re: 2003 P1406 code
Yep, the DPFE sensor is a snap to replace! Unplug it, yank it off the steel sensing lines and replace.
Joel
2016 Subaru Forester 2.5i base CVT
2016 Nissan Quest SV
Old 08-29-2006, 07:42 AM
garync1 garync1 is offline
Re: 2003 P1406 code
That was fast just log on to put answer and 2 more poped in.. The above are true.
Old 08-29-2006, 07:50 AM
reekor reekor is offline
Re: 2003 P1406 code
Check with your local dealer, it might still be covered under warranty if the mileage on the van isn't too high.
His, 96 Limited, 5.2 Magnum, Magnaflow CatBack System, HID Head & Fog Lamps, 242 T-case swapped , Rear Trac-Loc. Chrome grill added to match the wheels.
Hers, 96 Limited I6, 242 T-case, HID Head & Fog Lamps.
