Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 07-20-2006, 01:24 PM
Blaiser17 Blaiser17 is offline
Send a message via AIM to Blaiser17
Big timing issue
Alright, well I got the belt on and in time. All marks right on the money. Tension is equivalent to what it's supposed to be. I go to start it up to set the ignition timing, and now the crank pulley is way out of wack. Meaning thew sprockets gotta be outta time too. How is that possible though if both camshafts are still right in time? I tried playing with the crank angle sensor, but nothing useful came of it. This is the 2nd time this has happened. Somehow the timing marks up top are right, and the bottom ones change somehow. Anybody have any ideas, I'm gettin desperate. Thanks.
1999 Chevy Monte Carlo 3.1L
1991 Chevy Camaro 3.1L
1981 Chevy Camaro z28 383 Stroker
2000 Mercury Cougar v6
Old 07-20-2006, 02:11 PM
Talon69's Avatar
Talon69 Talon69 is offline
Send a message via AIM to Talon69 Send a message via MSN to Talon69 Send a message via Yahoo to Talon69
Re: Big timing issue
you have to go around a few revolutions to get all the marks to line up again. Did you do this? Not just 1 time around.
Current Cars
2006 Eclipse GT 6 speed MT (V6 3.8), mods so far- S Tech Springs, after market 18's, 2012 headlight Conversion, Greddy cat back exhaust, CAI, RRE Headers, Polyurethane Motor Mounts, NX Nitrous kit at 100 shot for now, RPM Window Switch, Triple Pod.
2003 Grand AM GT - official beater car for the winter lol
95 TSI AWD [email protected] (T-25)
Now fully Modded engine with 3,560 miles on it.SOLD
Old 07-20-2006, 09:43 PM
It's twice, but yea I did that. I found out the problem though. In the balance shaft kit I had bought the stubby shaft you use to replace the lower blance shaft had no oil groove in it for it to be lubricated. This was fine at first, but as time went on, the oil would heat and because they are two different types of metals (the housing- aluminum , the stub shaft - steel), they eventually just bonded. I hammered the shaft out and am debating whether to cut grooves in it, or just cut off the end of one of my balance shafts and use it to circulate the sprocket. But anyways, the timing belt would just jump the oil sprocket because the shaft locked up and the oil pump sprocket wouldn't turn. This would make the two camshafts still be on time on top, but the bottom timing marks off. Very weird. But now I'll put it back together tomorrow and it should be fine. Thanks guys!
Old 07-24-2006, 10:04 AM
kjewer1 kjewer1 is offline
AF - Advisor
WTF, another pair of threads on the same topic from the same poster. You guys are on a roll today!
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
