Old 07-20-2006, 10:36 AM
DRW1000 DRW1000 is offline
Spark Plugs
I was in my local auto parts store yesterday and I noticed a new line of Champion double Platinum plugs. I looked at the packages and they specifically mention that they are platinum on both the centre and the ground electrodes. Perhaps this will be a 3rd option besides the Motorcrafts and the Autolites. They were $13.49 CDN per pair. I paid about $8.00 per for the Motorcrafts from Ford and the quote I had for the Autolites was about the same.
Old 07-20-2006, 03:41 PM
phil-l phil-l is offline
Re: Spark Plugs
Did you get a look at the plug electrodes? Yes, double plats have the distinctive 'nubs' of platinum on the ground electrode.
Yes, it'd be nice if there was another quality supplier of double-plat plugs. If anyone has tried them out, we'd love to hear what you think of them.
2000 Windstar LX 3.8
1995 Contour GL 2.5
1986 Mustang GT 5.0 --> Sold, but missed on sunny days
Old 07-20-2006, 04:57 PM
Re: Spark Plugs
Yes I should have mentioned it. I did look at them and on the top of the ground (facing the centre) electrode there was the small cylinder of Platinum.
Old 07-20-2006, 06:09 PM
Death to Ford Death to Ford is offline
Re: Spark Plugs
I have just put in the NGK iridium spark plugs and wires and they are fantastic. The van runs so good and starts everytime and I feel so much more power just from these plugs and wires. I personally like NGK products made in Japan over the motorcraft ones which are designed by bosch.
Old 07-22-2006, 01:44 PM
cacique cacique is offline
Re: Spark Plugs
Did you put the plugs in yourself. My pesonal mechanic had a difficult time uninstalling and installing the plugs and the wires.
Old 07-22-2006, 02:10 PM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: Spark Plugs
Save the champion for cry/dodge/jeep/and certain import
Ford just loves OEM motorcraft.
And remember OEM parts only hurt one time.
Go to switching around and you may get bit in the rear many times.
The only time you need double plat is when you have neg. and pos. firing cylinders.
MT
MT
Old 07-22-2006, 02:28 PM
Re: Spark Plugs
I did mine myself - but I'll admit that the 3 rear plugs were a pain. Very difficult to reach.
1995 Contour GL 2.5
Old 07-22-2006, 03:12 PM
Re: Spark Plugs
I had a hard time with the back ones too but only the first time changing the spark plugs is a little tough if I were to change them again it would be very easy. I prefer myself doing them over a ford dealer charging me a heck load of money to do it
Old 07-22-2006, 07:36 PM
Re: Spark Plugs
MT
Which is exactly what Windstars do
Old 07-22-2006, 09:55 PM
Blue Bowtie's Avatar
Registered Offender
Re: Spark Plugs
Exactly right. Oddly, when the wasted spark systems were first introcuded, Ford had two different part numbers for their plugs on opposite sides (electrically) of each coil. One had a platinum center electrode, and one had a platinum side electrode. They continued this for several years, and finally discovered that it was more efficient and foolproof to simply stock double platinums and avoid the confusion. I've run into those odd sets on several 3.8s, and it's always confusing.
Additionally, and it's just my opinion, but there is nothing wrong with Champions in almost any engine, provided they have the correct heat range, reach, and metallurgy. What is NOT my opinion is that the only plug manufacturers making plugs with FAA approval are Auburn and Champion. Good luck finding Auburn plugs for your car, so the only available brand good enough to fly but made for your car might be Champion.
NGK has a very good ceramics and metallurgical R&D center, and produces a reasonable quality plug. Plain steel AC/Delco (non platinums), Bosch (including the +4s), Autolite (no longer Ford but purchased and cheapened by Allied Signal - the group responsible for Fram crap), and all those designer brands (like SplitFire) are maybe just good enough for a lawnmower - Maybe. That IS an opinion, but I'll stick to it.
Old 07-23-2006, 10:59 AM
ModMech's Avatar
ModMech ModMech is offline
Re: Spark Plugs
I would NOT use anything but OE Ford/Motorcraft plugs.
"Will fit" is not the same as "Designed for".
Old 07-23-2006, 03:55 PM
Registered Offender
Re: Spark Plugs
No doubt that if you want OEM reliability, OEM parts are hard to beat.
Old 07-23-2006, 09:21 PM
Re: Spark Plugs
I pulled out two different types in my 99. The 2 types were installed in the factory. From what I understand is they are only available at the factory and dealers only stock the double platinums.
Old 07-23-2006, 09:39 PM
Registered Offender
Re: Spark Plugs
The two part numbers are still available? That's almost senseless, but I suppose they get requests for them once in a while.
Double platinums will work very well. As long as there is a platinum electrode on the negative polarity terminal of the plug (which is different on different sides of each ignition coil) the plugs will last just as long - Perhaps even longer. I've done the switch to full (double) platinums on quite a few 3.8s with no problems over many subsequent miles.
Old 07-23-2006, 10:33 PM
wiswind wiswind is offline
Re: Spark Plugs
FORD says to use the double platinum plugs.
The single platinum plugs.....platinum on alternating sides....are used at the factory.....I guess they save some money....with no impact on performance of the plug.
Stocking 1 part number, double platinum, spark plugs for each application makes a LOT of sense.
Moderator for Ford Windstar room only
Links to my pictures, intended as an aid, not a replacement for, a good repair manual.
1996 3.8L Windstar
http://www.flickr.com/photos/4157486...092975/detail/
2003 Toyota Sienna pictures (not much there yet)
http://www.flickr.com/photos/4157486...781661/detail/
