Old 08-12-2002, 11:34 PM
Dudley03 Dudley03 is offline
Will the LS engine fit
Hey my friend just totaled his 90 integra ls and i can get his engine for next to nothing and it only has 70 k on it. what work will be invovled in doing this and what will i need other than what will come out of his car. will it be work it. how will performance be? has anyone done this? any help is appreciated.
Old 08-12-2002, 11:39 PM
the engine is also automatic so what will be involved in making it standard? just a new tranny or will i need a new computer and clutch, etc...???
Old 08-12-2002, 11:41 PM
91zc 91zc is offline
It is pretty easy depending on your model. You will need:
Bolt in mount kit and shift linkage
Complete motor, transmission, ecu, axles, and intermedaite shaft from the integra.
Depending on you model civic you might have to do some wiring changes
From what I hear the performance is good. Low end torque is really good but it is not like a b16 up top. I would go for it. And while you are swapping replace a lot of the wear and tear items. Otherwise you will be kicking yourself when you have to change them when the motor is in the car.
91 civic 4dr
b16a
14.8@94
Old 08-12-2002, 11:43 PM
Ok since it is auto, you will need:
Clutch and flywheel
Transmission
ECU
All these can be obtained from another donor teg. I would replace the clutch with either a new stock one or an aftermarket clutch.
91 civic 4dr
b16a
14.8@94
Old 08-13-2002, 12:16 AM
civicHBsi91's Avatar
civicHBsi91 civicHBsi91 is offline
Send a message via AIM to civicHBsi91
looks like too much work and money for just a ls with 70k on it, i would buy it and sell it *depends on how much you get it for*
2002 Acura TL Type S
1991 Honda Crx Si
Old 08-13-2002, 02:08 AM
civickiller civickiller is offline
Send a message via AIM to civickiller
nah the b18a is a good motor, i am dropping in a b18a in my car with 80k on it. the auto ecu would work with a standard tranny but you will probably have a lower rev limiter. cause my friend with a b16a has an auto ecu in his car and it works but he has a lower rev limiter. yeah and get the standard tranny with a new clutch
yeah we need to know what model you got. cause you might need a resistor box too. you gotta watch out when buying an ecu cause you said its from a 90 teg which makes it a obd0 comp, if you buy a 92-93 teg ecu its obd1 and idk if it will work wiht a obd0 engine
i am hopefully gonna be swaping in the ls motor at the end of august. if you havent done it by then, then i can help you after
