Closed Thread Show Printable Version Show Printable Version | Subscription Subscribe to this Thread
Old 07-20-2006, 07:47 AM
nuggetray nuggetray is offline
Send a message via MSN to nuggetray
Smile 2000 pontiac grand am hazzard switch noise
i have replaced the hazzard switch part#22642605 309 2575 and i still hear the ticking noise coming from the switch, and the hazzards are not on. help please,cant afford the dealership.:
Old 07-20-2006, 08:53 AM
BNaylor's Avatar
BNaylor BNaylor is offline
Re: 2000 pontiac grand am hazzard switch noise
Since you've replaced the hazard switch the next possibility is the multifunction switch (stalk).
Timeslip 08/12/06
AF Community Guidelines
Old 09-15-2006, 08:08 PM
af_boy20 af_boy20 is offline
I have the same problem with a 99 grand am. The clicking is very sporadic and the lights do not flash when it does this. When I use the signals or hazards they work fine. I have also replaced the hazard switch in the dash. I would rather not just throw parts at the problem till it is fixed. Has replacing the the switch (stalk) on the steering column worked for anyone else? Any other Ideas? Thanks.
Old 09-18-2006, 12:09 PM
xeroinfinity's Avatar
xeroinfinity xeroinfinity is offline
out saving the world
yes replacing the part on the steering colum is the fix if the hazzard switch has been replaced and yuo still get that clicking noise.
1999 Grand Am SS 3.4 OHV
Old 09-25-2006, 12:31 PM
rickant rickant is offline
I have a 2003 Grand AM GT ... just started to have the same problem...signals and everything work but it keeps clicking even when you shut if off...I'm getting aggravated with this car and GM. I recently had the coolant light come on and was down fluid... mechanic says IMG gasket... GM won't fix it. My family has had probably 30 GM cars over the past 40 years ... might be be time to move on.
Old 09-30-2006, 07:17 PM
highflyer100's Avatar
highflyer100 highflyer100 is offline
We had the turn signal clicking problem on a 2002 Grand Am, replaced the multifunction switch and problem solved. I'm told this is a common problem with these cars. The part was about $150.00 at the dealer. The only problem I had with this repair had to do with the horn. There is a small spring loaded silver button on the front of the multifunction switch. This button must contact the ring plate or the horn will not work. When I installed the new switch I must have pushed the button in too far and it stuck. No horn, had to remove the switch again and free up the button. It all works for now!
Old 10-03-2006, 03:51 PM
Thanks for the advise. Autozone had the multifunction switch assembly for $79. I replaced it and haven't had any problems yet, although I havent had much time to drive it lately.
Old 01-25-2007, 02:17 PM
Sandman302 Sandman302 is offline
f your turn signal demon is still present, here is your solution!
My 01 Grand Am had this same problem and many others that I've talked to have had the same problem on others years as well.
It's been a year since I've done this, but here are the basics. Take the plastic clam-shell off the top of the steering column. This will simply pull apart with a little effort. You will probably need a small screw driver of some kind to take out the screws holding the turn signal/wiper control machanism. There are also a couple of electrical connections that need to be disconnected. Make sure that it pulls out smoothly, don't try and force it. I don't know how much they cost to replace but what a hassle that would be. Anyway, once you've got that out take it inside so you can take it apart over a counter or table with good lighting. Remove the screws holding the two halves together. NOTE: there is a small spring that might come out of one of the sides, make sure you get that back in and don't lose it. Now you should see the contacts that make the turn and wiper levers work. Very likely you will see the contacts covered in a copious amount of grease. Clean that off with some Q-tips or something non-abrasive like a can of compressed air. Keep enough grease on there to retain smooth operation of levers. Reassemble and reinstall in car. NOTE: there may be a small pin on the top of the steering column that has to be pushed in to allow the mechanism to slide back in. There are also guides to make sure its seated properly.
This worked like a charm for me and I didn't have to hassle with some dealer who wanted to charge me an arm and a leg to replace everything.
Good luck!
Sandman302opcorn:
Old 01-25-2007, 04:20 PM
Sandman302 DO NOT bring up old threads, this is closed!
Closed Thread
