Old 07-20-2006, 02:36 AM
2poor2tune's Avatar
2poor2tune 2poor2tune is offline
Send a message via AIM to 2poor2tune
d series piston bore
are the pistons way of for the bore size in the d series motors or are they all the same size? i have a d16a vtec and i think i might need to replace the pistons and rings.
Old 07-20-2006, 03:49 AM
YZ125rider21's Avatar
YZ125rider21 YZ125rider21 is offline
Send a message via AIM to YZ125rider21 Send a message via Yahoo to YZ125rider21
Re: d series piston bore
all d series pistons are the same bore (75mm) but they do have diff compressions! but I have no clue why you would not bore it out .20....
90 Honda CRX Si
-Red/Black
-B20B/b16
-AEM CAI -/\- Apexi GT Header/2¼" Custom Dynomax Exhaust
-Tein SS CoilOvers with pillow ball monuts -/\- ST Swaybars/Energy Suspension Bushings
-16x7 Lightweight Rotas -/\- Pro Stop Rotors -/\- Goodridge S.S. Brake Lines
-Skunk2 Shifter -/\- MoMo Steering Wheel
Old 07-20-2006, 11:26 AM
2poor2tune's Avatar
oh because im just looking to rebuilt mine for now. not trying to make it fast yet. thanks for the help
Old 07-20-2006, 12:32 PM
well no sense in rebuilding it if you are not gonna bore it out .20 and have it honed....thats the right way to do it and you will be able to sleep easier at night
90 Honda CRX Si
-Red/Black
-B20B/b16
Old 07-20-2006, 02:51 PM
TheSilentChamber's Avatar
TheSilentChamber TheSilentChamber is offline
Forunn Daberator
No point in boreing it over. As long as its properly honed it will be fine.
Old 07-20-2006, 04:56 PM
Bunger's Avatar
Bunger Bunger is offline
The stock platue hone from honda is VERY good, and inless there is some serious wear or scratches that can catch a fingernail, there is really no reason to bore, unless you're going for more power.
Also, check zealautowerks in my sig for a great compression calc, you can figure out what pistons will give you what compression with your setup.
Old 07-20-2006, 04:57 PM
2poor2tune's Avatar
do i need to take it to the machine shop for that? or do i just clean up the cylinder walls with the proper tools?
Old 07-20-2006, 05:09 PM
Bunger's Avatar
You could buy a hone to use on a drill, but it may not even be needed... check out how your block looks first.
Old 07-20-2006, 06:32 PM
FrodoGT's Avatar
FrodoGT FrodoGT is offline
Those drill hones can leave the bore out of round so you have to be very careful when using them.
Cheap, Fast, Reliable..Pick two
Current project:
Rio Red 91 hatch.
A6/Z6 build, Hondata S300, Tokico illumina/Ground Control.
"I'd rather run 12's on steelies than 15's on rotas."
Old 07-20-2006, 08:25 PM
Hybrid1990crx's Avatar
Once in awhile you make a post worth posting lol.
Anyway this man is correct, drill style hones are TRAAAAAAAASH. They don't make it out of round technically though, its more of a egg shape. The middle will be slightly larger then the top and bottom like this ()
Old 07-20-2006, 08:46 PM
2poor2tune's Avatar
thanks alot guys. i will look into that stuff. and if anyone has anytips for the piston transplant shoot. thanks
Old 07-20-2006, 08:50 PM
take it to a machine shop and get it honed properly, then get it hot tanked or atleast wash the cylinder walls down with warm SOAPY water. then reasemble. i thought your 4 door had a d15 vtec in it? hows it so beat already?
Old 07-20-2006, 08:51 PM
2poor2tune's Avatar
oh and can i use my old hf pistons and it will still be an ok compression or should i just get some z6 pistons. i really just want it to run for cheap. so basicly the usuall.
Old 07-20-2006, 08:53 PM
well being that HF's are 8 valves, the pistons will not work.
get some z6's.
Old 07-21-2006, 01:41 AM
Forunn Daberator
It depends on what type of hone you use, I agree that the ball hones and the three stone spring loaded ones are junk though.
