Go Back   Automotive Forums Car Chat > Pontiac > Sunbird/J2000/2000 Sunbird
Old 07-19-2006, 10:19 PM
bucsfan bucsfan is offline
head bolt torques
does anyone know the head bolt torques for 1985 pontiac 1.8. If possible torque sequence also. I can probally come close on the sequence, but no clue on the torque values.
Old 07-20-2006, 08:59 AM
MrPbody MrPbody is offline
AF -Advisor
Re: head bolt torques
Depending on VIN Code, according to Flepro's handbook:
Code "O" or "0", 1st step, 18 lb. ft. 2nd step, turn 60 degrees, 3rd step turn 60 degrees, 4th step turn 30 degrees, 5th step, warm up engine, last step, turn 30-50 degrees.
Code "D", 1st step, 21-36 lb. ft., 2nd step (new bolts) 83-98 lb.ft, (used bolts) 90-105 lb. ft.
Sequence is a "spiral", starting at the two center bolts and "winding" your way out.
The VIN "Code" is the eighth digit in the VIN.
Jim
