Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 07-19-2006, 08:57 PM
1968 Pontiac's Avatar
1968 Pontiac 1968 Pontiac is offline
Cool Can I add a coolant level sensor to my rad?
I found a nearly new three core brass rad in the wrecker a few weeks ago for my 91 Caprice Classic. I had the rad checked and cleaned at a local shop. I was about to install the rad when I noticed it didn't have the socket for the level sensor. Can such a thing be bought and added to a rad? I looked at Rock Auto but couldn't see anything listed for my car. Thanks.
1949 Chevrolet 1433 (Canadian 1 ton cab and chassis single rear wheel pick-up truck)
1968 Pontiac Parisienne (rust free survivor)
1973 Buick Centurion (four door hardtop; engine will be donated to our 1949 1 ton truck)
1989 Chevrolet K3500 RC/LB (454 & single rear wheels)
1991 Chevrolet Caprice Classic (police cruiser clone)
1992 Chevrolet K2500 EC/SB (almost rust free daily driver)
1998 GMC C1500 EC/SB
Old 08-07-2006, 08:08 PM
Re: Can I add a coolant level sensor to my rad?
Bump ... still wondering if anyone has done this.
Old 08-07-2006, 08:19 PM
Blue Bowtie's Avatar
Registered Offender
You would have to dismount the tank (radiator shop again), cut a hole, and braze in the level sensor bung. It would be a lot of work (again) for a level sensor.
Old 08-07-2006, 08:22 PM
CD Smalley CD Smalley is offline
Couldn't one be added to the recover tank easily? That's where the factory puts them isn't it?
CD
1991 W41 #142
1989 Caprice 9C1
1997 C1500
1997 Bonnie SE
1998 Olds 98 LS
Recently updated: http://forums.b-body.org
Old 08-09-2006, 09:15 PM
The factory puts them half way up the tank on the right side of the rad. Putting a level sensor in the overflow would be ok, but I don't think it may always indicate a rad leak since fluid is drawn out of the reserve as it cools. Of course it would have to be below the 'cold' line, but if you have a stone go through your rad when it's still cold, it may be too late for your heads/engine by the time the fluid is drawn into the empty rad. Also, I think there is some liquid lost to evaporation over time, so the sensor would give a reading for a non-existant emergency. And, last, but most importantly, since our Chev's handle like BMW's (LOL), the sensor on the overflow would always be going off while we're flying around corners at tremoundous speeds only seen at the Brickyard!
I looked in my GDI rad book, but didn't see a brass rad that fit this car that had a level sensor. I would have thought that such a beast would have come in a Buick Roadmonster at the very least.
The rad isn't in the car yet, so it's no problem to add the bung. I thought someone may have a make/model for the bung if it is available as a separate item. The current rad in the car has plastic tanks so the bung is molded into the tank. I've make my way back to the rad shop to see if I can get a bung. I have torches, so it's no problem to solder the bung into the tank. Thanks.
