Go Back   Automotive Forums Car Chat > Jeep > Grand Cherokee | Grand Cherokee SRT8
Old 07-19-2006, 08:21 PM
mdbrantley mdbrantley is offline
Angry 93 JGC larado 4x4 is still running hot
I have a 1993 jeep grand cherokee larado All time 4x4 that i am having problems with it over heating while i'm at a stop. I have replaced the water-pump, the radiator, the hoses, the anti freeze, idler pully. I am at awe as to what is going on with my truck. if any one can help, i'd be much abliged.
Old 07-19-2006, 10:01 PM
bringselpup's Avatar
bringselpup bringselpup is offline
Re: 93 JGC larado 4x4 is still running hot
I get the sense there's some opinion regarding replacement radiators themselves. 3 row, 2 row, plastic tank, metal tank etc.
Maybe what you have fits and has all the connections in the right place but just isn't doing the job?
93 ZJ White 4.0L PowerTech I6 with +215K miles - Brembo up front Yakima on top Red Top under the hood
Old 07-20-2006, 07:24 AM
Caribbean ZJ Caribbean ZJ is offline
change your fan clutch. When this dont work properly it usually shows when the jeep is stopped
Old 07-20-2006, 11:08 AM
we already changed that too. i just replaced the trani about 2 months ago and they instaled a transmission cooler in the front. i was wondering if that could be the problem. we took out the therm. it'll run around 170 to 185 but when i stopp for appr. 5 or more min. it climbs to almost the red line. but once i get going it will shoot back down.
Old 07-20-2006, 11:09 AM
we already changed that too. i just replaced the trani about 2 months ago and they instaled a transmission cooler in the front. i was wondering if that could be the problem. we took out the therm. it'll run around 170 to 185 as im driving down the road ,but when i stop for appr. 5 or more min. it climbs to almost the red line. but once i get going it will shoot back down.
Old 07-20-2006, 12:02 PM
put back the tranny cooler, its the best jeep upgrade ever. Your problem really sounds like a fan clutch one. Did u do t-stat and rad cap too? Sometimes the cheap fixes work. try em first. Hope u aint uused the old cap on the new rad.
Old 07-20-2006, 03:10 PM
we replaced the fan clutch,radiator,radiator cap, t-stat, took out the t-stat, hoses, antifreeeze, seems like everything. i just realized today that if i turn off the a/c it dosen't over heat AS FAST but it still trys to. I'm at a lost. any thing else you can think off?
Old 07-20-2006, 03:11 PM
Also, what if i install an electric fan? it now has a new clutch fan.
Old 07-21-2006, 10:00 AM
you said you did hoses as well. Did the new hoses have the spring inside them. if not the can get sucked closed from the pull of the pump. You can also take the rad cap off when cold, start the jeep and after 10 mins keep pressing the upper hose to "burp the system" so you can get all the air out. You seem to have done about everything so far. Did the problem get any better with any change u did, or is it the same?
Old 07-21-2006, 10:09 AM
AngelouS AngelouS is offline
i dont reccomend taking the thermostat completely out. It will rush through the radiator to fast before it can cool down. I would just put one back in. run a 210 degree or less. thats most likely the cause. It did the same on my 93 4.0
Old 07-21-2006, 06:47 PM
Exclamation Re: 93 JGC larado 4x4 is still running hot
It still runs the same as it did. Like I said, it will only start to run hot when I'm at a stop for app. 5 min or more. once I get going, the temp will come back down. I'm at a lost.
Old 08-21-2006, 02:25 PM
mobby mobby is offline
I agree with the other guy on this issue, more thasn likely a fan clutch issue. Try and take it to like jiffy lube and get it flushed while it runs and get an junk out then verify tht your NEW fan clutch isnt bad. I would say its a bad NEW fan clutch..
