Old 07-19-2006, 06:19 PM
kchew kchew is offline
86 S-10 Blazer A/C problem. Please help!
I have an 86 S-10 that I converted to 134 about 8 years ago. It's been sitting for a year and lost the charge. Now I'm recharging it but having problems. There is no difference in high side/low side pressures. I'm pretty sure that the compressor is pumping, and I know that the clutch is kicking in. I also replaced the expansion valve. It doesn't seem to be sucking up much freon when I charge it, but it will build pressure to 130 lbs (both sides). Does anybody have any ideas??? Thanks for the help!
Old 07-20-2006, 07:05 AM
rlith's Avatar
rlith rlith is offline
Send a message via AIM to rlith Send a message via MSN to rlith
Re: 86 S-10 Blazer A/C problem. Please help!
You have a leak in the system somewhere. That needs to be tracked 1st. Next you need to have the system vaccumed before you throw in the freon. Also for giggles I would check the condition of your orifice tube and your pag oil.
Old 07-20-2006, 09:38 AM
I'm going to flush the system with cleaner and replace all the O-rings. I put a new orifice tube in it. I also make sure to vacuum it down before I recharge it. Do I need to add more oil? And if I do, do I use PAG or Ester oil? Thanks again!
