Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Suburban
Old 07-19-2006, 03:22 PM
whiplash3e whiplash3e is offline
96 sub with soft brakes
I had to jump on the brakes hard one night to miss a deer, ever since then I have a soft feel on the brake pedal. I changed the brake booster, to get rid of the whoosing sound, but that did not cure the pedal feel. Any Ideas? Thanks
Old 07-23-2006, 07:12 PM
Joe Bloggs Joe Bloggs is offline
Re: 96 sub with soft brakes
how did you replace the booster. I thought it was hydraulic boost from the power steering pump. any way I got soft brakes too and no one seems able to fix it. I blew a gront brake line and since it got replaced I have had it in 3 different brake shops and they cant get my truck to have good brakes like it use to
Old 07-25-2006, 02:28 AM
94sportsedan 94sportsedan is offline
I believe the K2500's had the hydraulic brake booster. 2ndly, there is a TSB for brake proportioning valve replacement 96-99. Helps engage the rear brakes a tad quicker resulting in less nose dive and a firmer pedal.
Old 07-25-2006, 09:20 AM
Thanks 94sportsedan for the info... Could you give me more on this? Like where to find it and what it is called so I can get one.. Thanks
Old 07-25-2006, 04:09 PM
TSB 9905240001
PN#12548265 dealer or gmpartsdirect.com
About 20-45 minutes to replace, depends how rusty the brake lines are.
Then Just need to do a brake bleed job.
Old 07-25-2006, 04:39 PM
Thank you for all your help 94sportsedan....
