Old 07-19-2006, 01:33 PM
Polygon's Avatar
Polygon Polygon is offline
The Red Baron
Send a message via MSN to Polygon Send a message via Skype™ to Polygon
Low oil pressure?
I just want to know if this is normal for our cars or not. Last weekend I took my new R/T TT to get the emissions and safety done. While driving back I noticed that the oil pressure wasn't really that high. It was just below the mark I would assume was normal pressure range. Then when I got home and the car was idling in the garage the oil pressure had dropped to almost the bottom. Is this normal? The oil light has never come one. I haven't had time yet, but I'm going to check the oil level and I'm changing it anyways this weekend.
Also, I beat on the car a little on the way down to the emissions place to warm up the cats. I am having problems with grinding while trying to shift fast. I don't know if it me not pushing the clutch in far enough or if I have a real problem here. If I shift slower it is fine.
Old 07-19-2006, 03:10 PM
2old 2old is offline
Re: Low oil pressure?
1) yes, the oil gauge in our cars vary quite a bit... I wouldn't worry about it unless it does not climb when you are running at higher RPMs... But if you feel paranoid, check the oil level.
2) Yes, most of our cars do that unless you have the syncronizers rebuild (and even then it depends on how fast you are "mashing gears")... Try and match revs when you shift.
Old 07-19-2006, 04:04 PM
VR43000GT's Avatar
VR43000GT VR43000GT is offline
Send a message via AIM to VR43000GT
Agreed, synchros are a common flaw in the 3/S. And the oil pressure guages are known to be rather unreliable. Mine always says the oil pressure is a little low but does climb back into the "normal" range as my rpm's really start to go up. Nothing to really worry about. But as said, check your oil anyway. I usually check mine every other day anyway no matter what car it is because I just dont trus the guages on cars.
Old 07-19-2006, 04:12 PM
Polygon's Avatar
The Red Baron
Well, I'm going to check on the oil tonight when I get home. I'll just have to get used the clutch I guess. I'm used the GTC which is a cable driven clutch and has quite a bit of modulation and this Stealth doesn't.
Thanks for the help guys.
Old 07-19-2006, 07:57 PM
Igovert500's Avatar
blue + red light magnet
do a search for low oil pressure on 3si if you want a few hours worth of reading material. Most of our cars have an issue with it, luckily mine doesn't yet, but that doesn't mean much to me...the general concensus is most of our stock gauges really aren't accurate enough for the general car enthusiast. Aftermarket gauges are really the way to go.
Stealth316-> garage -> AWD oil change and use Redline fluids
That and start double clutching
96 3000gt vr4
-K&N FIPK
-Proboost mbc
-Greddy type-s
-ATR downpipe
-no cats
Old 07-19-2006, 10:47 PM
YogsVR4's Avatar
YogsVR4 YogsVR4 is offline
Funding the welfare state
Send a message via AIM to YogsVR4
If the oil level is fine then I wouldn't worry - as long as it doesn't stay on the lowest reading.
Resistance Is Futile (If < 1ohm)
Old 07-20-2006, 09:25 AM
Polygon's Avatar
The Red Baron
Well, I checked the oil last night and it was over the full mark. I wonder, if the person that owned it before me used a thin oil if that would cause an overly low reading? I am changing the oil on Saturday with some Mobil 1 15w50 and I'm hoping that will correct the problem.
Old 07-20-2006, 02:28 PM
YogsVR4's Avatar
I wouldn't think the thickness of the oil would consufe the pressure gauge.
Old 07-20-2006, 09:29 PM
youngvr4's Avatar
youngvr4 youngvr4 is offline
STREET RACING GURU
it wont, i use to use 20 50w and it doesnt make a difference
the guauge will only show whats really going on with the oil in the engine unless your at high rpm,s 3000 and up, otherwise it just drops
and it sounds like your blocking rings have gone bad, or are getting bad
is the grinding happening with all gears or just specific one's?
Old 07-20-2006, 10:45 PM
AutostradaVR4 AutostradaVR4 is offline
the stock gauge is garbage. I recall reading on 3si that someone was able to raise their pressure reading just by cleaning the sensor. Also, someone replaced the stock gauge with a new stock gauge and it read completely different. I wouldnt worry about it. An aftermarket gauge is a must on these cars. In case you havnt figured it out, the stock boost gauge is WAY off too. Just dont run it low on oil and youll be fine.
Formerly BlinkRA182
--VR-4-- --09 Lancer RALLIART-- --Me--
Old 07-21-2006, 07:32 AM
liquidPunk's Avatar
liquidPunk liquidPunk is offline
Send a message via AIM to liquidPunk
My oil pressure guage is completely broken... shows flat all the time (unless ive been running with no oil... hmmm... ill be right back... AHHHHHH )
But at least it doesnt give me a false sense of security... i check my oil most every day... but ill get it fixed eventually.
1992 Mitsu 3000gt sl 5sp
- High flow filter - Pioneer head, dual 10's - H4 headlight conversion
- Throttle Body Spacer - The "For God's sake stop that infernal buzzing" mod
- LED "Snake Eyes" - Lightweight Crank Pulley
-More to come-
Your 3000GT is the 5095th out of 6964 . Only 41exactly identical
Bloody Knuckles from Changing Fuel Filter Crew Member #1
Old 07-21-2006, 09:53 AM
Polygon's Avatar
The Red Baron
The grinding happens only when I'm shifting fast. I have only been up to third so far while doing that. So it did it in second and third. As for the gauge problem, this is really bothering me. Can I have a shop test the oil pressure? I don't want to spin a bearing.
Old 07-21-2006, 11:50 AM
sLADe781 sLADe781 is offline
Originally Posted by liquidPunk
My oil pressure guage is completely brolen... shows flat all the time (unless ive been running with no oil... hmmm... ill be right back... AHHHHHH )
It took me forever to find the lines that connect to the oil pressure and oil sensor. LOL I looked and looked and looked a bit more but couldn't find it until one day I was down there doing something else and randomly saw the two line. Hehe
Old 07-24-2006, 10:45 PM
Polygon's Avatar
The Red Baron
I just wanted to post an update.
I changed the oil Saturday. I spoke with the previous owner and he is not sure what oil was last used as he did not own it long enough to change the oil. Seems some old lady owned it before him and I'm sure she took it to an oil lube place. After changing the oil that was VERY apparent.
First off the oil was overfilled. The next problem was that the filter was on too tight so I had to jam a screw driver through it to get enough leverage to loosen it. They also didn't lube the gasket on the oil filter. The oil was very black and not very smooth. I assume that it was 10w30 conventional. That and the fact that the oil smelled. I think it had been sheared and broke down. I filled it with about 4 1/2 quarts of Mobile 1 15w50 full synthetic. As soon as I started up the car the oil pressure went up to the normal operating range. Tomorrow when I take it down to the car wash to degrease the engine I'll see how that holds up once the car is up to operating temp.
Alright here is another update, and some more worries.
1. After going down to wash it and let the car warm up the oil pressure stayed just below the normal operating range. At idle it was about two ticks from the bottom.
2. The coolant overflow cap won't stay on and it keeps dumping coolant. The engine temp stays under the middle, but I wonder if the engine is getting too hot and that is contributing to the oil pressure issue?
3. On my way down to the car wash, when I got to the bottom of the hill from my house and turned on to the main road, as soon as I hit a bump it started making a clunking noise from the rear. There was no pattern and it increased with speed. As soon as you would hit the brakes it would go away. This continued after the I washed the car for about a mile and then it went away. I kept hitting bumps to try and get it to come back but it wouldn't make the noise again.
Any ideas?
Old 07-25-2006, 12:48 AM
Linebckr49's Avatar
Linebckr49 Linebckr49 is offline
Send a message via AIM to Linebckr49
1. that's normal for our cars. at idle the gauge reads low. when you give it gas, the gauge will rise, then fall as you let off the gas.
2. since you discovered the engine had too much oil, perhaps there is too much coolant in the engine?
3. not entirely sure. i would think it could only be a few things: (a)perhaps driveshaft? (carrier bearing, u-joints, i dunno i don't have a TT), (b) perhaps it was something in your trunk? make sure the trunk trays are secured underneath the carpet cover. make sure contents of trunk trays aren't bumping around. also, make sure the spare tire is securely fastened. these things all have moved around in my car and make clunking sounds like you described when i hit bumps. also, perhaps the exhaust in the rear isn't as secure as it should be. check the mounting points from where it hangs and their respective rubber bushings.
honestly, i wouldn't worry about it that if the noise went away, and you couldn't bring it back after re-creating the circumstances.
93 3000GT base
K&N | long tube headers | 3sx crank pulley| testpipe | Addco front/rear sway bars (3SX) | rear strut bar & front 3-point strut bar (by JonVr4 on 3Si) | solid motor mounts | LSD insert | KYB GR-2 struts | intrax springs | adj. control arms | ss brake lines | 16% taller 5th gear (teamrip.com) | H4 conversion | push-button start | datalogger | HKS S-AFR | PLX WB O2
coming soon: adj. cam gears | bi-xenon HID retrofit
