Go Back   Automotive Forums Car Chat > Chrysler > PT Cruiser | PT Cruiser Convertible
Old 07-19-2006, 12:36 PM
D_A_V_E D_A_V_E is offline
Battery Removal
Any tips on how to easily change out car battery? They don't leave you much room in there.
Old 08-15-2006, 03:36 PM
fordin K fordin K is offline
Re: Battery Removal
if I remember correctly you have to remove a whole lot of junk like air intake duct and stuff around battery.
Old 09-02-2006, 03:42 PM
Etraveler13 Etraveler13 is offline
Re: Battery Removal
Just had my battery replaced. The battery was under $40 (Interstate from Walmart), I watched the guy. Remove the air filter top by unclipping two clips. then the filter, pull it out, next the air filter box. Unscrew the one hose in the back. the battery box pulls out (no tools needed), don't worry that you have to wiggle it out, its held in with rubber grommets. Once it is out of the way, you will have full access to the battery, and plenty of room.
Good luck
Old 01-31-2007, 08:41 AM
mikels_ranger mikels_ranger is offline
Re: Battery Removal
Etravaler13 is right. I just replaced my battery in my '03 cruiser. Easy change.
Old 01-31-2007, 11:21 AM
Re: Battery Removal
Did you also have to replace the battery wire? I replaced the post on mine. I am considering a replacement for the filter box to alleviate this problem, The cone shaped filter. Do you have any experience with them? Its like a K&N filter.
Old 01-31-2007, 03:00 PM
Re: Battery Removal
Yeah I also had to replace the positive cable. It was all corroded.
I haven't had any experience with the K&N type filters, but I will also
be looking into it for my Cruiser. Right now it is the only vehicle out of 3
I have running, so I had to get it right the first time.
If you find something useable let me know, or if I find something I will let you
know.
Later
