Old 07-19-2006, 03:47 AM
ikeyballz ikeyballz is offline
Send a message via AIM to ikeyballz
LT1 not turning over at all..
okay, so this is a late 'problem' its more of a solution, actually.. my sisters Z28 was having starting problems, it wouldnt turn over, it had the solenoid clicking, it would have problems recharging the battery, etc. we changed the battery once, twice, changed the alternator, still happened, then one day, NOTHING turned on, not even the lights!
the problem? really badly corroded terminals, but since the Lt1 battery clip are the side-ways one, with the plastic/rubber cover over it, its really hard to tell. reading a DMM on the battery+ to the ground would also give 12V, so we even thought it was the computer...
no. such an easy problem..so..guys with LT1s..be careful of that crappy connector. im thinking of crimping a top connector onto mine..i wonder if the hood will still allow it to close?
Car:
1997 M6 SS Camaro [ white ]
285's in the back
all else = STOCK.
Old 07-19-2006, 09:09 AM
wrightz28's Avatar
wrightz28 wrightz28 is offline
is bring'n sexy back
Re: LT1 not turning over at all..
Taht's a common problem on quite a few late 80's to mid 90's GM's. After confirming battery voltage, the next test is amperage.
Old 07-20-2006, 02:02 PM
FormulaLT1's Avatar
FormulaLT1 FormulaLT1 is offline
Fight the powwa!!!
Send a message via AIM to FormulaLT1 Send a message via MSN to FormulaLT1 Send a message via Yahoo to FormulaLT1
I had a similiar problem once that turned out to be a loose ground. It was fine when the key was turned in the run position but the minute you went to draw power to the starter all lights and chimes went dead then went the key was put back in the run position not start again everything would come back on.
RIP Hypsi - I just want to express I will never be the same after having lost such a good friend. You meant alot to me and I feel I am a better person for having known you. Til the day we meet again my friend you will always be in my heart.
Mods: Weight reduction (I don't wear underwear)
Old 08-29-2006, 03:38 AM
Falkor87Z28 Falkor87Z28 is offline
had the same problem with my Z28, after changed the battery we found it. Im pretty sure my dad went ahead and changed it to top connectors when i wasnt around, maybe he only did one, i really dont know, but the hood closes fine $)
