Old 07-19-2006, 01:14 AM
LewisDubya LewisDubya is offline
Some Newb Questions
I'm working on a fujimi f430 and painted some parts with tamiya acrylic (XF-number). Displeased with the result, I tried stripping the paint with tamiya thinner, which worked incompletely as I still have minor patches of acrylic paint on the parts. I was wondering whether or not I could spray over these parts with tamiya TS as I understand TS should not be applied over acrylic. Moreover I asked the hobby shop guy who mentioned that if I waited a few days for the acrylic to totally cure it would be okay and the paints would not react.
My second question is whether or not Tamiya surface primer can be sprayed on parts which I later intend to brush with Tamiya acrylic paints and whether or not it's recommended. It seems that paint doesn't adhere well to some of the smoother surfaces, for example the dash and was wondering if I sprayed primer on first, I could use less paint thereby not reducing the details. I do not own or have access to an airbrush.
Thanks!
Old 07-19-2006, 06:53 AM
cyberkid's Avatar
cyberkid cyberkid is offline
Re: Some Newb Questions
Thanks!
OK first here is Tamiya Paint Tutorial, read through these and you'll have a lot of your Q's answered. Note the chart at the bottom of that page.
1 :Stripping Arcylics: 90+% alchohol if paint has cured, can also use Windex before its cured.
2: Paint Layering: Although it isn't recommended, Lacquer can be misted over Acrylic BUT bleeding is possible.
3: Shinny parts: most poeple sand down the places being painted with 800-1000 grit wet-dry sandpaper to give the paint better grip.
4: Primer: I personally recommend primering everything... A lot of people say that this is an overkill.. but I'd rather be safe.. and it gives me better results.
5: Paint Layering: If you only brush paint... then.. hrm... go easy.. and consider a AB
Please read the following linked articals before posting a question.
Once you have and still have questions, try to post your questions clearly.
This will make a lot of people's blood pressure drop back to normal, including mine.
NEW TO THE AF MODELLING FORUM? PLEASE READ THIS FIRST
AF Car Modeling Tutorial, How-To and Product Review Depository
AF Car Modeling Frequently Asked Questions [FAQ] - * Look here first! * ver2.0
And finally,I wish you all happy modeling
Old 07-19-2006, 06:15 PM
Some_Kid's Avatar
Some_Kid Some_Kid is offline
well as for your stripping acrylic question use some rubbing alcohol it will take it right off you can put it on a paper towel and just rub the parts and it should come off
