Old 07-19-2006, 12:00 AM
rental blazer rental blazer is offline
key won't come out
i need to know how to get the darn key out of the ing. asap it won't come out..it is in park..
Old 07-27-2006, 08:11 AM
bbcnutt bbcnutt is offline
Send a message via MSN to bbcnutt
Re: key won't come out
I had the same thing happen on my 96 Escort... If and when you get the key out it won't go back in and you won't be able to start tha car at all....... You will have to have new lock put in.. Has to be drilled in two places to get the pins out. I got a new lock (autozone online only) and had a locksmith do it for 100.00 (lock was 27.00) You have to know just where to drill so you don't mess up the holder or the wiring.. Hope this helps...
Old 07-28-2006, 12:26 PM
KimMG KimMG is offline
AF - Advisor
If you don't remove the key, removing the tumbler is fairly easy.
Disconnect negative battery cable
Turn the ignition lock to the run position
You will see a little hole on the tumbler. insert a small allen wrench (stiff wire, straightened paper clip) and release the tumbler.
Try cleaning and lubricating the tumbler or otherwise replace.
Old 06-13-2007, 12:57 PM
93escortman 93escortman is offline
try turning the wheel back and forth and then try pulling the key out, and try shifting from park to nuetral and back to park and try again.
hope this helps
Old 06-13-2007, 05:44 PM
Davescort97 Davescort97 is offline
Escort guy
This thread is dead. It is from July 28 of last year. Please start a new thread rather than reviving a dead one.
