Go Back   Automotive Forums Car Chat > Nissan > Murano | FX45
Old 07-18-2006, 10:19 PM
rconlee rconlee is offline
infiniti fx45 keyless remote programming instructions
I bought a remote for my infiniti fx45 and need programming instructions.
Thank you,
Old 01-16-2008, 04:04 PM
umoms umoms is offline
Re: infiniti fx45 keyless remote programming instructions
Hey I also have a 2005 Infiniti FX45 and need porgramming instructions. Did you ever find this?
Old 01-20-2008, 08:14 PM
FixUrNissan's Avatar
FixUrNissan FixUrNissan is offline
do you have an I-Key or a regular remote. ( Meaning do you need to use the key to start the Vech ) Let me know, i could help with your programing the remote issue
Old 01-21-2008, 04:10 PM
Not sure which one I have but I don't need the key to start the vehicle. Just as long as I have the remote in the vehicle.
Old 01-29-2008, 10:34 AM
the way you program the remote is in this pattern-
get in vech lock all doors, then push key in ignition in and out kinda slow (not turning the ignition) till the hazzard light flash, then turn the key to the on postion, and hit remote lock button. Lights should flash again, ( if you have another remote, with master switch unlock door and relock then hit lock on second remote) when done turn key off unlock doors open door then close and test.. it should work..
Old 04-03-2009, 10:57 AM
sprklegrl8 sprklegrl8 is offline
umoms and rconlee
DID YOU TRY THESE INSTRUCTIONS???
Do they work?
Let me know, i am ready to do my 05 FX35 and don't want to have to run to the dealer in an emergency if it doesn't work or messes up my only working remote.
Thanks!!!
