location of turn signal flasher
I have a 2001 Oldsmobile Alero. My turn signals do not work, the hazard warning lights do work. I was wondering whether there is a separate turn signal flasher or if the flasher is part of the hazard warning light switch. If there is a turn signal flasher where is it located, I can't seem to find it.
Re: location of turn signal flasher
its part of the hazard switch on the dash panel
Had this problem with my daughter's 2001 Alero also, The Hazard Flashing switch fixed both problems. Hope this helps
9/4/2003 Mfr. Involved GENERAL MOTORS CORP. NHTSA Campaign # 03V327000 Mfr. Campaign # 03043 Component Affected EXTERIOR LIGHTING:HAZARD FLASHING WARNING LIGHTS:SWITCH # Vehicles Affected 670740 Defect CERTAIN PASSENGER VEHICLES HAVE HAZARD WARNING SWITCHES THAT MAY EXPERIENCE SOLDER JOINT CRACKING CAUSED BY RAPID TEMPERATURE TRANSITIONS AND THE SOLDERING PROCESS. IF SOLDER JOINT CRACKING OCCURS AND RESULTS IN AN OPEN CIRCUIT, THE TURN SIGNALS/HAZARD LAMPS BECOME INTERMITTENT OR INOPERATIVE. Consequence WHEN THE TURN SIGNALS ARE INOPERATIVE, THE DRIVER CANNOT USE THEM TO SIGNAL INTENT TO TURN THAT COULD RESULT IN A CRASH. Corrective Action DEALERS WILL REPLACE THE HAZARD WARNING SWITCH. OWNER NOTIFICATION BEGAN ON FEBRUARY 5, 2004. OWNERS SHOULD CONTACT CHEVROLET AT 1-800-630-2438, PONTIAC AT 1-800-620-7668, OR OLDSMOBILE AT 1-800-630-6537. |
POSTING IN CLOSED OR OUTDATED THREADS: If a thread has been closed, there is probably a logical reason for it. If you feel that the reason(s) for closure of the original thread are unjustified or wish further clarification feel free to contact any member of the moderating team. However, do not start a new thread about another closed thread. Please avoid posting or voting in outdated threads. It merely clutters up the message board and makes it more difficult for fellow members to sort through the vast amount of information contained on the boards. If you have new and important information to add regarding a past discussion, feel free to start a new thread and if need be, add a link to the original thread.
