Go Back   Automotive Forums Car Chat > Pontiac > Bonneville
Old 07-18-2006, 08:36 PM
MERC_DoD MERC_DoD is offline
92 Bonn electrical problem
Hoped in car it turned over strong, drove it about a block,shut it off. When I tried to re start 5 minutes later it acts like it only has a few volts in battery. Horn barely blows and headlights weak. Then suddenly lights are bright horn blows strong but when I try to crank everything goes weak again. Cleaned connections at battery (no help), turn lights back on, weak still, then boom lights go bright and strong again but when I try to start, weak again. Will test with meter tomorrow and will also check connections opposite battery. Any ideas? I know the battery is ok.
Old 07-18-2006, 10:25 PM
jd-autotech jd-autotech is offline
Re: 92 Bonn electrical problem
Maybe Battery Cables Are Bad Rotten Under Outer Wire Case
Old 02-28-2007, 11:30 AM
Was a bad battery.
