Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 07-18-2006, 08:30 PM
violent31601's Avatar
violent31601 violent31601 is offline
Send a message via AIM to violent31601
psi level
ok all you guys that know me, knows that i don't really know too much of anything about my car. However I am learning and am loving it.
anyway my question is about 3 weeks ago on the stock turbo i noticed i was getting about 14 psi on the T-25 turbo but now all of a sudden i'm only topping at about 10. If its boost leek how do i go about finding out how i'm getting it
thanks guys
Old 07-18-2006, 08:35 PM
gthompson97's Avatar
gthompson97 gthompson97 is offline
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
Re: psi level
Boost leak test. Vfaq.com > Intake > Intake leak testor.
95 Talon TSI AWD
97 Eclipse GST
Old 07-18-2006, 09:14 PM
Killa's Avatar
Killa Killa is offline
Re: psi level
or you can buy a boost leak test, that came with a gauge, that tell you how many psi your are pump, so you dont have to run around, and look at your boost gauge, or tell your mom sit in the car, and watch the boost gauge for you, I told my mom sit in the car and I adjust the biss crew, so she can watch the rpm drop .
GM FOR LIFE !!
NEW 1997 Camaro z28 6 speed
illa never going back to import , but killa alway be nice to any DSM he saw
looking for 2002 Trans Am LSX
UPGRATE 2010 !! 97 Camaro Z28
95 camaro lt1
1992 Pontiac Firebird v6 auto -sold -
Pony 1998 Mustang GT 4.6L Manual. Black
1995 Eagle Talon TSI AWD Turbo manual R.I.P
1994 Mitsubishi Eclipse Manual gray -Sold
1997 Mitsubishi Eclipse RS Auto White - Sold
Old 07-18-2006, 10:01 PM
NOFX0617's Avatar
NOFX0617 NOFX0617 is offline
Send a message via AIM to NOFX0617
Re: psi level
I am doing the same thing right now....
1998 Eclipse GSX
6 Bolt swap
MHI Big 16g
FP Race Manifold
Apex'i N1 Cat-back
Apex'i N1 Downpipe
Walbro 255 fuel pump
GReddy Type S BOV
Turbo XS Boost Controller
Balance Shaft Elimininator
ACT 2600
RRE 11lb No Name Flywheel
Prothane Motor Mounts
Tokico Illuminas Advanced Handling Kit
RRE Front and Rear strut tower bars
RMDSM Front and Rear Sway Bars
TRE Stage 2 Tranny
ARP Head Studs, Main Studs, Rod bolts
Old 07-19-2006, 06:35 AM
Re: psi level
is stock psi suposed to be 14 or 10?
Old 07-19-2006, 02:53 PM
crunchymilk55's Avatar
crunchymilk55 crunchymilk55 is offline
Send a message via AIM to crunchymilk55
Re: psi level
anywhere inbetween, 14 is normal though, that's where I was.
now - 2000 civic
soon - 2002 is300
Old 07-19-2006, 02:56 PM
4g63gst20 4g63gst20 is offline
Send a message via MSN to 4g63gst20
Re: psi level
14 psi , a couple months ago, when i was in CA smoking some civics, the hose that goes from the IM to the BOV came off and i was only boosting 10psi, so that could be your problem.
-MODS-
Autometer Boost,Oil Presure,And Water Temperature Gauges./Geddy Turbo Tmer/Eibach Sportline Springs Matched With Adjustable Iluminas 4 Corners/Konig 18" On Nitto Extreme 555/ACT 2100 PP with Street Disc/Extended Push Rod/Urethane Motor Mounts/XS Power FMIC. 28X10.5X3.5/Greedy Type RS BOV/ evo3 16g Turbo/MBC At 18PSI/Bian Crower 272 cams/SAFC2 With 510cc Injectors/Walbro 190 FP/
1/4 mile=14.3@103MPH
Old 07-19-2006, 06:48 PM
Re: psi level
well thats what is happening to me but everything seems secure and tight
this is a really noobish question but could it have something to do with my boost gauge, like the line not screwed in tight enough or whatever?
Old 07-19-2006, 06:56 PM
Thor06's Avatar
Thor06 Thor06 is offline
Jizzed In My Pants
Re: psi level
IIRC, the stock 2g's run 14, while the stock 1gs run 10.5.
Build on hold until I get a good paying job, either in school or once I get out. At that time a full tear down and complete rebuild should be in order.
The Purple People Eater will ride again... January 2011 can't come soon enough.
Old 07-19-2006, 06:57 PM
Re: psi level
It's possible. If you're using the really crappy nylon tube that comes with most boost gauges, they kink really easy, and tear holes. Autometer sells a copper tube for 15 bucks, well worth it.
now - 2000 civic
soon - 2002 is300
Old 07-19-2006, 10:05 PM
Re: psi level
so i could have a link/kink through my boost gauge and that could be screwing with my boost?
Old 07-19-2006, 11:18 PM
Re: psi level
I did. The nylon hose kinked and punched a hole through it giving me bad boost readings. Mine happened to kink inside the cabin so I could hear the hissing.
now - 2000 civic
soon - 2002 is300
Old 07-20-2006, 12:10 AM
Re: psi level
i'll check into that, thx
Old 07-20-2006, 03:24 PM
Re: psi level
Hey thanks alot crunchymilk55, that was the problem, its reading 15 again. So i was prolly getting 15 the whole time, the gauge was just reading 10 then?
did that make me lose power?
Old 07-20-2006, 03:29 PM
Re: psi level
yep, it's a minor boost leak, but still a boost leak. I'm glad you got to it before you started tinkering with other stuff. They sell that autometer copper tubing kit at Oreily's for 15 bucks. Your welcome.
now - 2000 civic
soon - 2002 is300
