Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 07-18-2006, 02:20 PM
sincere88 sincere88 is offline
400 big block
hey guys its me again.has anyone ever heard of some dropping a 400 big block into a 88 caprice if so,whats the process like? thanks for your help Chevy Boyz!!
Old 07-18-2006, 03:45 PM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
Re: 400 big block
400 big block? What make? Although Chevrolet advertised one for the 1971 model year, it was really a 402 - and that in turn was a 396 factory overbored .030".
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness!
1967 El Camino L79/M20 old school asphalt raper
Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have.
Old 07-18-2006, 04:48 PM
broughy84's Avatar
broughy84 broughy84 is offline
Re: 400 big block
there's not a 400 big block. There's a 366, 396, 402, 454, but not a 400. However there is a 400 small block, which would be the same outside specs as any other sbc.
Matthew Brough
1997 Geo Prizm -- 301,000 miles
2000 Honda Accord -- 225,000 miles
2004 GMC Yukon XL -- 223,000 miles
1987 Jeep Comanche -- 116,000 miles
Old 07-18-2006, 07:06 PM
HLandin's Avatar
HLandin HLandin is offline
Re: 400 big block
Correct, the 400-cid was a small block. Its basically a bored 383-cid. The major problem with the 400-cid was that the cylinders were siamesed, which caused the block and heads to overheat.
Old 07-18-2006, 07:19 PM
Blue Bowtie's Avatar
Registered Offender
Re: 400 big block
The overheating potential is really overblown. It really doesn't happen that often, and there are easy things which can be done to minimize or eliminate any overheating problems. Surely, the potential for hot spots is slightly greater, but it's not as common as some would have you believe.
FWIW, if you perform the math, a "402" is actually 0.029" larger in bore (to make it a nice, round 4-1/8" bore) - Close enough.
Which do you really have? The 400 was only made for a few years, too, even though there are a lot of aftermarket siamesed bore blocks out there, and a ton of 406s and quite a few 426 SBCs on the street.
Old 07-18-2006, 07:57 PM
silicon212's Avatar
Confoundingly Lucid
Re: 400 big block
Correct, most Chevrolet NASCAR engines are built with the 4.125" siamesed block (albeit one designed for the purpose). If these can run 500 miles WOT without overheating, the 400 should be able to have a managed cooling capability.
Old 07-18-2006, 09:37 PM
1968 Pontiac's Avatar
1968 Pontiac 1968 Pontiac is offline
Re: 400 big block
I had two 73 Caprice ragtops which came with 400 small block's. Never had a problem with overheating. The only problem I had with both was baaaad gas mileage; about 10mpg which rivalled my 67 Lincoln Continental winter car I had at the time. With one of them I did however add headers, crower cam, aluminum intake, HEI, Holley 600 carb, shift kit, etc. and managed to boost the milage to 20mpg. The other one I pulled the 400 sbc for a 425hp 454. Mileage wasn't bad at 16mpg, but it sure was a lot more fun to drive!
1949 Chevrolet 1433 (Canadian 1 ton cab and chassis single rear wheel pick-up truck)
1968 Pontiac Parisienne (rust free survivor)
1973 Buick Centurion (four door hardtop; engine will be donated to our 1949 1 ton truck)
1989 Chevrolet K3500 RC/LB (454 & single rear wheels)
1991 Chevrolet Caprice Classic (police cruiser clone)
1992 Chevrolet K2500 EC/SB (almost rust free daily driver)
1998 GMC C1500 EC/SB
Old 07-18-2006, 10:06 PM
'97ventureowner's Avatar
'97ventureowner '97ventureowner is offline
Re: 400 big block
I rebuilt a 400 sb into a high performance 406 which made it into a few of my Chevys . I was aware of the potential for overheating especially with boring it out .030 . I installed a 4 core radiator and used a high flow, high performance cooling fan( 5 blade) with no problems.
Thought for the Day… Alcohol does not make you fat - It makes you lean... against tables, chairs, floors, walls and ugly people.
If a prostitute here in America loses her job to a prostitute in India , is that considered "outwhoring"??-Jay Leno
" A Good Thing To Know"
Old 07-19-2006, 08:32 PM
ilgoldstein's Avatar
ilgoldstein ilgoldstein is offline
Re: 400 big block
I looked through a beautiful "coffee table" book on the SBC today at Borders. It indicated that the 400 SBC did not really put out much more HP than the 350 and got worse gas mileage. When it came out, Motor Trend panned it.
The book is a real nice item, has a lot of history on the development and deployment of the SBC through the years, although I caught some ommisions, and the info was sketchy at times. Lots of pics of great cars.
I go in from time to time and will get the author and title.
1995 Buick Roadmaster Sedan
1989 Cadillac Sedan De Ville
1964 Chevrovet Malibu SS
Old 07-19-2006, 09:26 PM
silicon212's Avatar
Confoundingly Lucid
Re: 400 big block
The 400 was never a "Horsepower" motor - it was not designed to rev high with its 3.75" stroke and 4.125" bore. What it did, and did well, was pound the asphalt with gobs of low-end torque to spare. That's one reason why it was popular in some trucks until its discontinuance in 1980.
Old 07-20-2006, 12:18 AM
1986Z28's Avatar
1986Z28 1986Z28 is offline
Has a Camaro
Send a message via MSN to 1986Z28
Re: 400 big block
guy in my neighbourhood did it, actually pretty cool, btw guys he learned the point the first time its a 402 not a 400, no need to keep repeating it
Formerly Blownalcoholboy
1986 Z28, 400ci SBC, Twin borg warner billet S467 turbos, Reid case powerglide, Moser 9". Holley EFI, Boost Leash. 950RWHP on pump gas, 1200rwhp on race gas (22 psi)
Best ET 1/4: 8.35 @ 170mph (275 drag radial)
Best ET 1/8: 5.44 @ 132mph (275 drag radial)
Best 60': 1.31 on the back tires (275 drag radial)
AF User Rules/Guidelines
http://www.automotiveforums.com/vbul...uidelines.html
Old 07-20-2006, 01:42 PM
Re: 400 big block
so the "400 big block" is actually a 402?am i right? is there a way to run a 402 or even a 454 i a 88 caprice?
where can i find a nice set of vogues from for cheap?
Old 07-20-2006, 02:28 PM
capriceowns capriceowns is offline
Re: 400 big block
no, the 383 isnt a block size. its a 350 with a longer stroke.
400 is actually a 389 pontiac engine bored over. or at least the original one was. idk much after that.
Old 07-20-2006, 08:39 PM
1986Z28's Avatar
Has a Camaro
Re: 400 big block
id say its a 402, because chevy never made a 400ci mtor other than a sb
Old 07-20-2006, 09:18 PM
silicon212's Avatar
Confoundingly Lucid
Re: 400 big block
In 1971, Chevrolet offered its 402 big block as a "400 big block" which is where the confusion comes in. You're right, there was never an official 400 big block, but Chevy did market one for one year.
