| Cavalier Problem Diagnosis Got a problem you can't fix? We can help. |
code 42, bubbles in radiator
89 Cavalier with 46,000miles. 2.0 TBI
Car showing a 42 code since yesterday. Car lost all coolant after heater core split. Replaced heater core and was running cooling system flush through cooling system with radiator cap off and foam continuously came out of radiator neck. I filled radiator to top to eliminate room for foam and could see bubbles continuously coming out of radiator core. Car never overheated before heater core replacement, just happened to notice radiator was empty. Blown head gasket or cracked head possibly. Don't know how long car was driven without sufficient coolant. How do I check without removing the head to check. No water in oil either, at least not yet. Code 42 showed up yesterday when starting car to drive it up on ramps, I have been having intermittent poor acceleration problems sometimes accompanied with an occasional misfire. Have replaced the TPS, spark plugs, fuel filter, air filter and MAP sensor for poor running / starting problems which the TPS fixed with the exception of the occasional poor acceleration / misfire. My Chilton says that code 42 is Electronic Spark Timing bypass circuit grounded. How do you go about troubleshooting this? Last edited by rknorr; 07-18-2006 at 03:32 PM. |
Re: code 42, bubbles in radiator
update: I don't know why but when I flushed the cooling system with clean water and put in antifreeze the bubbling stopped so maybe I got lucky and nothing is damaged AND the 42 code went away. Only thing I did was do a compression check, all cylinders were between 170 and 175psi. Still got the occasional reluctance to accelerate problem though.
The code 42 is back accompanied with misfire and hesitation during acceleration, when running at a steady speed you can feel the engine isn't running right like it has a slight misfire then too. I'm thinking the DIS module might be bad, what do you all think?
anyway whats 42?
1999 Chevrolet Monte Carlo LS [semi-daily driver until LIM repair or trade-in for '13 Fusion, 110k miles] Gone but not forgotten: 1995 Pontiac Grand Prix GTP[sold, 128k miles] 1996 Oldsmobile Cutlass Supreme SL Coupe [a minivan tore my door off, totaled, 84k miles] 1998 BMW M3 Hardtop Convertible [a pathfinder armada stopped in front of me, totaled, 70k miles] 1989 Chevrolet Cavalier Coupe [died, 160k miles, engine problems] 1990 Hyundai Excel GL [died, 220k miles, died] |
