Old 07-18-2006, 11:47 AM
lenwlod lenwlod is offline
Bose radio display out
I did something stupid, jumped another vehicle and connected the cables to the fuse box, not the battery. No big deal, blew out the 125 amp large fuse on the outside of the block. Replaced that, everything works except my Bose radio dispaly. The radio works, all the buttons etc. including the steering wheel buttons. Checked the manual to see if there is a fuse for the display, can't find one. Any ideas?
Old 07-18-2006, 12:51 PM
rodeo02 rodeo02 is offline
Re: Bose radio display out
Did you check the fuses near the BCM under the rear seat? Something may have blown there. These trucks do have super sensative electronics. Even if you accidentally arc a metallic tool across the battery terminal, something will blow.
Joel
2016 Subaru Forester 2.5i base CVT
2016 Nissan Quest SV
Old 07-18-2006, 01:47 PM
I did check that fuse block, nothing in the manual indicates "radio or clock display" fuse, checked most of the other ones, nothing appears to be blown. I am thinking there maybe an inline fuse coming off the radio itself?
Old 08-09-2006, 12:28 PM
Still have not figured out this one. Any ideas?
Old 01-09-2007, 11:05 PM
andrewalex andrewalex is offline
do you know where I can get the 125 amp fuse?
Old 01-10-2007, 04:09 AM
I had to go to the dealer, they had one in stock. Also as an update, I was able to warranty out the old radio, they replaced it with no questions asked.
Old 02-06-2007, 04:13 PM
rnoord rnoord is offline
I did the exact same friggin thing this morning. I just bought the #48 125 fuse at the dealership. Did any of you guys install the new fuse yourselves? Seems easy ehough. Any suggestions?
Old 02-07-2007, 12:01 AM
If I remember correctly it is attached with two nuts. Just make sure you disconnect the hot coming from the battery before proceeding (rather obvious, but I wouldn't have had any problems in the first place if I has been thinking!).
Old 02-07-2007, 02:05 PM
Replaced the fuse and everything is back in order. The Bose stereo display included. Thanks for the feedback and info. Saved me a lot of hassle.
