Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 07-18-2006, 12:22 PM
wanaplay134 wanaplay134 is offline
Send a message via AIM to wanaplay134
high idle
i searched but nothing helpful so ill ask
i finally finished my motor and it runs good but when i start it it idles at like 2500. i checked my cam angle sensor and tried adjusting that got nothing. my biss screw does nothing. my iac is brand new so i doubt it that my ecu is brand new. so anyway everything i check is not working any help would be good. i thought maybe a vacumm leak but im runing like 19-20 vac at idle which i thought was really good.
1992 eagle talon tsi awd
xtd stage 3 six puck/apexi 3' downpipe and exhaust/ngk plugs/taylor thunderbolt wires/manual boost controller set at 20psi/walbro 255 with rewire/autometer boost gauge/turbo xs rfl blow off valve/arp headstuds/ to4b vtrim turbo/dnp tubular manifold with o2 housing and tial 38mm wastegate/eagle rods/ross pistons/acl bearings/arp rod bolts/arp main studs/aeromotive fuel pressure regulator and all stainless lines/aem fuel rail/slowboy street front mount kit
Old 07-18-2006, 03:20 PM
Killa's Avatar
Killa Killa is offline
Re: high idle
Read my post, I fix it by ajust the TB cable, while the car still running and high idle, if the idle drop, your problem fix.
GM FOR LIFE !!
NEW 1997 Camaro z28 6 speed
illa never going back to import , but killa alway be nice to any DSM he saw
looking for 2002 Trans Am LSX
UPGRATE 2010 !! 97 Camaro Z28
95 camaro lt1
1992 Pontiac Firebird v6 auto -sold -
Pony 1998 Mustang GT 4.6L Manual. Black
1995 Eagle Talon TSI AWD Turbo manual R.I.P
1994 Mitsubishi Eclipse Manual gray -Sold
1997 Mitsubishi Eclipse RS Auto White - Sold
Old 07-18-2006, 03:22 PM
Re: high idle
thats probally it cause i made sure it was real tight this time for some reason thanks dude
Old 07-18-2006, 03:34 PM
4g63gst20 4g63gst20 is offline
Send a message via MSN to 4g63gst20
Re: high idle
so that was your problem? lol, it happened to me once, after i was done puting the head back where it belongs, the gas cable was basically opening the butterfly.took me a while to figure out what it was.
-MODS-
Autometer Boost,Oil Presure,And Water Temperature Gauges./Geddy Turbo Tmer/Eibach Sportline Springs Matched With Adjustable Iluminas 4 Corners/Konig 18" On Nitto Extreme 555/ACT 2100 PP with Street Disc/Extended Push Rod/Urethane Motor Mounts/XS Power FMIC. 28X10.5X3.5/Greedy Type RS BOV/ evo3 16g Turbo/MBC At 18PSI/Bian Crower 272 cams/SAFC2 With 510cc Injectors/Walbro 190 FP/
1/4 mile=14.3@103MPH
Old 07-18-2006, 03:45 PM
Re: high idle
yea now it runs at 750 and still has 19 vac so im pretty stoked time to break it in and tear up all the ricers in my area. theres a couple cars i really want to race one is a sr20det swapped 240 and a turbonetics kit integra i see them at the track all the time. the kid with the 240 is nice and the one with the integra is a typical honda guy and thinks he can beat everyone. i was runing 12.7s before i built my stroker motor and im even more modified now and i have an app. to get dyno tuned.
not that any of you guys cared but i was bored
Old 07-18-2006, 08:50 PM
Killa's Avatar
Re: high idle
good to know that work
GM FOR LIFE !!
95 camaro lt1
Old 07-18-2006, 08:52 PM
SLoe's Avatar
SLoe SLoe is offline
Re: high idle
^YAAAAAAAAAYYYY KILLER! You go boy!!
96 GST 5 spd.......(R.I.P.) smashed by a fallen tree
2001 Camaro SS 6 speed goodness!
Old 07-20-2006, 09:28 PM
kjewer1 kjewer1 is offline
AF - Advisor
Re: high idle
Guys, there is a specific way to set that cable properly. Look up the procedure I posted, and be sure it is set properly. It is very likely that doing it on the fly will fix the high idle problem, but may not allow full opening at full throttle.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
