Go Back   Automotive Forums Car Chat > Honda > How-To's and Walk-Through's
How-To's and Walk-Through's Here's where we show you how it's done!
Old 07-18-2006, 05:00 AM
Pac-Man_G Pac-Man_G is offline
Send a message via AIM to Pac-Man_G
any help i can get
well, i don't think my v-tec has been working so a buddy of mine got his P28 ecu and hooked it up to see it would make a different... its reved a little higher but as soon as i turn the car on the check engine light came on and was on the whole time. and every time i stepped on the break the cruise control light came on....WHAT THE HELL IS GOING ON? then i put my P28 in the check engine light didn't come on at all or the cruise control...anybody have any ideas? should i just go to the junkyard and get a new wiring harness from a 92-95 Si hatchback/Ex coupe and a P28 ECU? i need some major help...anybody want to shot me some ideas
Old 07-18-2006, 10:30 AM
AudioGuy93DelSol's Avatar
AudioGuy93DelSol AudioGuy93DelSol is offline
NA is Best!
Send a message via AIM to AudioGuy93DelSol
Re: any help i can get
So does your friends ECU work fine in his car? Or was it just sitting around and he grabbed it? What do you mean it revved higher? Like his rev limiter was set higher? Are you getting a check engine light when your car should be going into vtec with your ecu?
Oil leak? What oil leak? That puddle under the car is just sweat from all that horsepower.
"How many NASCAR passes is that worth? 500?" (Schumacher passing Raikkonen)
Emily is amazing, and she messed with my sig AGAIN!
Old 07-18-2006, 12:58 PM
ok, his ECU was just sitting around, the whole reason i didn't think the vtec was kicking in cuz it had a rev limit of 5500 RPM then the fuel would cut out, the check engine light only came on with his ECU and it was on the whole time the car was on...when his ECU was in it revved to 6250RPM but i still don't think the vtec kicked in cuz i hooked up a light to show me when it kicks in...any ideas?
