Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 07-18-2006, 12:12 AM
david-b's Avatar
david-b david-b is offline
Dave is THAT guy
Angry Vibrations from underneath
Hey all;
Out of nowhere the other day, there started a rattle coming from under the car. I turns out that the heat shield on the underside of the car where the exhaust runs decided to start rubbing up against the cat-back. IDK how this happened. It has not made a sound ever! Now all of a sudden, the heat shield vibrates off the flange connecting the first pipe to the second pipe at the bend in the center of the car.
I tried bending the shield back, it's hard, but I got it shaped so the flange isn't hitting at all. Only had a slight rattle at WOT at 3k rpm. Then, coming home, it was doing it badly again. Any ideas on how to stop this? It sucks because it rattles the most at idle. I'll be at a light and you hear boom boom boom rattle. So annoying. Any ideas on how to stop it? I'm going to try rebending again later.
2013 Chevy Sonic 1LZ
75 Monte Carlo
01 Pontiac Grand Am SE - RIP
Old 07-18-2006, 12:18 AM
gthompson97's Avatar
gthompson97 gthompson97 is offline
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
Re: Vibrations from underneath
Is there a support or mount or something broken on it, letting it come down and touch the exhaust? That would be my best guess. BTW, do you still need that TPS? I completely forgot about it until about 5 minutes ago.
95 Talon TSI AWD
97 Eclipse GST
Old 07-18-2006, 12:23 AM
david-b's Avatar
Dave is THAT guy
I've checked. It was fine. Everythings still secure.
Yes I still do. I actually thought it earlier today. Got the logger to read 5% at idle now and 78% WOT!! Let me know if you got any? How about a knock sensor too?
75 Monte Carlo
Old 07-18-2006, 12:28 AM
I'm going out their tomorrow to work on one of the Eclipses, I'm actually making a note as I'm typing so I'll remember to look. As for your exhaust sound, I have NO idea if everything is still in place and tight.
95 Talon TSI AWD
97 Eclipse GST
