Old 08-12-2002, 08:39 AM
obsidian66 obsidian66 is offline
Unhappy Frankenstein Swap
Has anybody Done a Frankenstein Swap? Im looking in to doing it. Need some Feedback on it, good, expensive, hard to do, worth the time and money?
Old 08-12-2002, 10:05 AM
marked001's Avatar
marked001 marked001 is offline
Moderadur
Send a message via AIM to marked001
there's more than one 'frankenstein swap'...mini-me, lsvtec, crvtec....etc.. try to be more specific
SOLD!
Old 08-12-2002, 02:46 PM
Well I guess that is one of my questions also? What is the best one to do? I was going to just do a b16 swap but then i was thinking b18 so im undecided what to sink my money into?
Old 08-12-2002, 02:50 PM
bc4g bc4g is offline
B18 if you are going turbo, B16 for street N/A
Chad
B C kit
motegi 15's
tenzo R seats
3'' exhaust 5'' tip
Old 08-12-2002, 09:37 PM
EF9JDM EF9JDM is offline
Send a message via AIM to EF9JDM
my opions
mini me = waste of time and $$ just get a SOCH vtec call it a day
Ls VTEC = good tork good power not alot of work but if you want it to last redo it right $$ wise not that bad
CR VTEC = crazy power and tork but alot of work gota redo the hole block if you want it to last. For the $$ you could just build a LsVtec and be strate
90 civic si
<Keep It Simple Stupid>
Old 08-13-2002, 02:39 AM
civickiller civickiller is offline
Send a message via AIM to civickiller
i still dont understand why people say the b16 is a bad turbo motor and hsould be used for NA
Old 08-13-2002, 09:26 AM
Will a b16a with JDM Integra Type-R Cams, JDM Integra Intake Valves, JDM Integra Type-R Intake Manifold, and JDM B-16a Pistons (p30) be good for turbo, and or nos? thats the motor I was planning on building.
Old 08-13-2002, 11:50 AM
EF_LSVtec's Avatar
EF_LSVtec EF_LSVtec is offline
Send a message via AIM to EF_LSVtec
Your set up will work, but will not last...P30 pistons are cast pistons and you need forged pistons for turbo or nitrous with of course matching rods if you want em to last. oh, and lower your compression too to maximize boosting.:flash:
AF Bay Area Crew
Fully Built LSVtec Motor (245.8 whp/164.6 torque)
88 DX Hatch to JDM SiR conversion
Retired SOLD 1/08
Licensed Mortgage Consultant (Calif.)
Cellular 415.699.1797
Old 08-13-2002, 11:59 AM
mellowboy's Avatar
mellowboy mellowboy is offline
Amy dragged me here...
Send a message via Skype™ to mellowboy
OR you can keep the stock compression and have less boost and STILL RUN THE SAME TIMES!
Old 08-13-2002, 01:21 PM
So just get diffrent pistons, and it should be good to go?
Old 08-14-2002, 11:43 AM
Phact's Avatar
Phact Phact is offline
Send a message via AIM to Phact
Originally posted by EF9JDM
my opions
i want to build a CR VTEC what engine parts would i need
Old 08-14-2002, 12:42 PM
marked001's Avatar
Moderadur
lotsa info... www.crvtec.com
SOLD!
Old 08-15-2002, 11:56 AM
How does one lower compression?
Old 08-15-2002, 12:35 PM
EF_LSVtec's Avatar
More space in the combustion chamber means less compression...best way to lower comp, is to replace your pistons w/lower comp ones...
AF Bay Area Crew
Retired SOLD 1/08
Old 08-15-2002, 02:47 PM
QuickSilverEF9 QuickSilverEF9 is offline
Send a message via AIM to QuickSilverEF9
N2O is retarded nuff said... Mustang blocks can handle it but push it through a honda block and you are asking for trouble> + it is a one trick show.. Turbo or superchargers give you the extra power all the time!
1997 Golf GTI VR6
-Leather Interior
-47000 miles
-JVC KDSH707 Head Unit
ON THE WAY
-2xInfinity Kappa Perfect 6.1 components
-12" Polk Momo sub
-JBL 600.1 amp
Future
-Brock B2 deep dish wheels
-Suspension.....
