Go Back   Automotive Forums Car Chat > Mitsubishi > Montero/Shogun/Pajero
Old 07-17-2006, 11:25 PM
bobdilts bobdilts is offline
Turn signal brain teaser
I just noticed that the turn signal lights are not on when the headlights are on. Are they supposed to be? They do start blinking when the blinker is on? If they are supposed to be on any ideas? Its a 98 sport and I checked the usual fuses but they seem OK (under the dash and left side of the engine compartment near the battery). My head hurts!
Old 07-18-2006, 11:37 AM
off-roader off-roader is offline
Re: Turn signal brain teaser
Can't say 100% what it might be. Have you added any accessories or components that might be rubbing on a wiring harness? I've had similar light issues that were caused when an accessory I added a year earlier wore through the wiring harness on the lights. Also, check your lighting relay in the engine compartment.
Hope you find the problem.
Old 07-19-2006, 04:24 PM
Thanks for the hints
No new accessories - I did replace the battery about 6months ago but tha's a pretty clean deal - I was hoping to put some fog lights in but haven't gotton around to that.
i did not look at the lights relay. I'll peek at that one.
Old 09-11-2006, 12:30 PM
Moz Mechanic Moz Mechanic is offline
Good day
I have had a simmilar problem with mine and after two weeks of swearing and frustartion I have found that I have a poor earth wire from the socket to the lamp.I experienced the problem only on the left hand side though.Maybe fit a test wire to the earth sockets of the lamp to test.I hope this helps
Old 11-22-2006, 10:23 PM
corvettefver56 corvettefver56 is offline
my 2002 montero sport had the same problem they just replaced the bulbs and cleaned the contacts everything is fine now i hope it works
