Go Back   Automotive Forums Car Chat > Dodge > Stratus
Old 07-17-2006, 09:15 PM
snoopyloopysk8a snoopyloopysk8a is offline
frankenstein the beast?
can a neon head bolt on to a stratus four with no mods?
Old 07-20-2006, 12:48 AM
Will183 Will183 is offline
Re: frankenstein the beast?
It depends on if the two motors are the same. Example, the 2.0 on similar years will bolt up fine. However, you will want to consult your local dealer or junk yard as they usually have reference manuals that say exactly what parts will fit on which cars.
Old 07-24-2006, 11:28 PM
so a 98 neon head + 98 breeze block should work out fine?
Old 07-25-2006, 01:34 PM
neon_rt's Avatar
neon_rt neon_rt is offline
If the Stratus is a 2.0 Sohc then you can use a Sohc head from a Neon.
If the Stratus is a 2.4 Dohc then you will have to put 2.4l cams into the Dohc Neon head before you install it.
The cam position marker on the cam is located at a different angle in the 2.4 vs the 2.0. You have to make that correction before the engine will run.
Old 08-10-2006, 02:43 PM
so is there a dohc head for the 2.0 that will bolt on?
Old 08-10-2006, 03:23 PM
neon_rt's Avatar
Yes, you can bolt the 2.0 Dohc head on in place of the Sohc head, but it isn't that simple.
You would need the intake and exhaust manifold also, plus you would have to check valve to piston clearance (since the valves are in a slightly different place. Your compression would reduce from 9.8 to 9.2 so you would loose Torque. The Fuel/Spark map would now be incorrect for the engine and it would not run very well. You would probably get a check engine light. Some have said that they have gotten a DOHC computer from a Neon to work in '97-'99 stratus' but the Tach doesn't work in that case. This only will work (such as it does) if the Stratus has a manual trans and the Neon computer is from a MTX neon of the same year.
