Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 07-17-2006, 07:43 PM
want_a_stealth want_a_stealth is offline
o2 sensor
my 1g dsm has an a/f gauge. all the sudden, it stops working (one light is on at all times) so i know that the wiring is ok. gas mileage is bad, around 15-16mpg. but i am boosting a lot.
could it be that the o2 sensor is messed up?
btw i also have really bad idle surge
Old 07-18-2006, 12:21 AM
gthompson97's Avatar
gthompson97 gthompson97 is offline
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
Re: o2 sensor
It sounds like you have more problems on your hand than you can fix at once. Vfaq would be your best bet right now. As for the bad MPG, you can try replacing the O2 sensor and probably your fuel filter would help. Fix any boost leaks if you any also.
95 Talon TSI AWD
97 Eclipse GST
