Old 08-12-2002, 04:15 AM
VTiracer VTiracer is offline
Send a message via ICQ to VTiracer
Unhappy Yikes...DEH-7100 HeadUnit dead?
Hi all..
I was driving in this morning listening to the radio at a low level...and suddenly I heard a crackle thru the speakers and the radio died.
Shutdown, some lights on the radio were on.
I pulled off the face and restarted. Came back on.. all radio station memory lost...tried to tune in.found station..all ok...tried to change the equalizer profile...no response...
I pulled off the face again.....restarted...nothing...some lights on the unit (are these diagnosis lights prehaps?)
My config is:
DEH-7100 (about 2 year old)
Pioneer 4-channel AMP with channel-B bridged
Front mids off Amp, rears off Headunit
Any ideas?
Thanks in advance,
James.
Do I have Oil? What you mean Oil? Of course....ohhh crap..
Old 08-13-2002, 11:48 AM
PaulD PaulD is offline
Audio Guy
Send a message via AIM to PaulD Send a message via Yahoo to PaulD
sounds like either you have a wire loose or dirty contacts on your face. To clean the contacts, take the face off and use a pencil eraser to clean the copper contacts on the face AND the box still left in the dash. Make sure you clean off all the eraser dust.
Old 08-14-2002, 04:29 AM
Hi PaulD,
Thanks for your reply.
I further notice that it mainly happens when I have the radio on rather than CD.
Also, when the unit hangs, I can actually remove the Face and the unit will still continue to play and audio will still be heard.
I can even take the key OUT OF THE IGNITION and the unit will stay ON !!!
It sounds to me like some internal electrical (like the power distribution board) component in the unit may be faulty and leaking current...i.e.
BATTERY - - - - -IGNITION
\ - - - - - - - - - - / <-- either a short between external wires
------- | \+X+/ | <--- or a short between internal power circuit
------- | UNIT |
I dont know.....then again could it be the firmware on the Unit or something? boggled
TIA for any suggestions...
James.
Old 08-14-2002, 10:30 AM
Audio Guy
that sure sounds like an internal problem ..... might be time to take it into the shop (as much as I hate doing that)
