Old 07-17-2006, 12:38 PM
im4an2idiot0 im4an2idiot0 is offline
quick question, in need of quick answer
ok well im resetting my gain for the system, and i just bought a new headunit and it has a option on the headunit for sub level goes from -10 to +10, when im setting my gains, should i put that level at 0 or at +10?
Old 07-17-2006, 02:27 PM
PlayStation3 PlayStation3 is offline
Re: quick question, in need of quick answer
it is up to you some might say since hu feeds the amp that it would better to have the hu up but others will say that it will just make your amp work harder then it has to
Old 07-17-2006, 04:52 PM
Mannyb18b's Avatar
Mannyb18b Mannyb18b is offline
Send a message via AIM to Mannyb18b Send a message via MSN to Mannyb18b
^ dont listen to that. What unit do you have? an Alpine it sounds like maybe. Other than that if it is not the alpine, the level control could be a boost for a certain frequency, an for that set your gains with it at 0. But remember if you turn that up with gains already set, you will clip the signal sooner.
300amp excessive amperage
Alpine H/U-
Incriminator Audio 20.1 @.35
(2) 15" Q's 8 cubes after 80sqin. 28hz
CDT EF-61's
Profile AP1040 on comps
NSB-100
Old 07-17-2006, 11:38 PM
JunkTitleGolf's Avatar
JunkTitleGolf JunkTitleGolf is offline
Some sony models also have it. My ex's did. They call it the Sub out feature. And it was adjustable.
1995 VW Golf
Cold Air Intake
Cat delete
Full straight pipe exhaust
4 gauge big 3
Pioneer head unit
Power Acoustik Amp
Cerwin Vega Vmax sub
Old 07-19-2006, 04:42 PM
PaulD PaulD is offline
Audio Guy
Send a message via AIM to PaulD Send a message via Yahoo to PaulD
set it at 0 when doing the gains and everything ... that will give you +/- 10 dB of adjustemnt if you need a little more or less bass - depending on the song.
Old 07-19-2006, 04:57 PM
00accord44's Avatar
00accord44 00accord44 is offline
High on Potenuse
Send a message via AIM to 00accord44 Send a message via MSN to 00accord44 Send a message via Yahoo to 00accord44
All the Sony Xplod's (that I've seen including mine) have Sub Preouts and controls. But I agree with PaulD, set your amp with the HU at 0 for Sub Control then adjust as you wish on the HU later keeping in mind that depending on the bass patterns, large variances could comprimise sound quality a little bit, but this is true either way you do it.
ECNATSISER AL AVIV
Old 07-20-2006, 02:18 PM
RickwithaTbird's Avatar
RickwithaTbird RickwithaTbird is offline
Send a message via AIM to RickwithaTbird Send a message via MSN to RickwithaTbird Send a message via Yahoo to RickwithaTbird
To get the bass as loud as it will play while still sounding good, you should have an equal amount of boost from all boost sources. Your sub out, gain, and amp's bass boost. A lot of times I find that if the HU is set to 0 then I have to turn the amp up too much. For this reason I like to start with the HU at +10. I turn the amp's bass boost and gain up equally until it is just too far, and then I turn down the sub a few notches. Maybe fine tune it just a little bit more, but this way when a song doesn't have enough bass, you don't have to distort your HU signal all the way to a 10db boost. You would only have to turn it to about 5 or 6 which is still a relatively good signal. And use that setting as a reference point.
It's more logical to have all your settings equal as opposed to a 0db boost here and a 10 db boost there. I'd prefer to have two 5db boost settings, and when that is too much, just turn the HU down. In this way, you don't have to turn your amp gains up so much for max volume.
edit: I also see why you would start at zero. I know that my way is just a preference. I just prefer an equal setting at all times cuz I'm a bass junkie and I like it as loud as the equipment can go.
R.I.P.: My Thunderbird "Ricks 96".. 2/08/96 - 1/14/05.
Old 07-20-2006, 08:37 PM
Mannyb18b's Avatar
^ or get better equipment
Alpine H/U-
CDT EF-61's
NSB-100
Old 07-21-2006, 11:38 AM
my 12" alpine type R's and my mmats 1000D qualify as good equipment. But universally speaking, that's a good point too.
Old 07-21-2006, 03:29 PM
Mannyb18b's Avatar
The way you set up your adjustments on your amplifiers is completley wrong. If you set up your stuff correctly, you would not need those "methods" you use, bass boost just boosts the signal at a "certain" frequency, usually 50hz or 45hz, which results in a peaky ass response. You might be able to stand it, but don't suggest those ways to other people, as they might have a better ear than you do.
Alpine H/U-
CDT EF-61's
NSB-100
Old 07-21-2006, 05:16 PM
Audio Guy
well, I often use my bass boost knob on my amp to help with my bass shelf curve to prevent having to use my EQ as much. I try and keep my EQ adjustments to no more than +/- 6 dB on any one band, to prevent inevitable sound quality degredation.
Old 07-22-2006, 12:07 AM
alphalanos alphalanos is offline
Just set your gain depending on the amp output, then use the level to fine tune bass depending on the song.
96 EJ6. Future home of boosted B18C1.
Old 07-22-2006, 02:28 PM
Like I said before you posted this response, it is my preference. I know what I'm doing. My equipment never needs to go beyond +6db boosts. I eq my system for my bass heavy music. I tried a million and one methods and I like this one the best for consistent/maximum bass performance. I said you may want to fine tune it a little bit more... But I'm not going to tell you how to wipe your ass.
Old 07-22-2006, 02:59 PM
Mannyb18b's Avatar
lol, ya, you were the one running sony xplodes an audiobling
an as oppose to your PM, I'm not really all that cocky jus have a wierd attitude seen on this forum, this is why I will be takin my opinions an statements elsewhere in the CA community where not everything is taken so seriously. Time to go win me some events!!!
Alpine H/U-
CDT EF-61's
NSB-100
Old 07-23-2006, 02:35 PM
bjboertje's Avatar
bjboertje bjboertje is offline
hey, paul is a god, i mean mod, again
2001 Ford ZX-2
Alpine CDA-9855
SAX 100.4
Rainbow CMX 265 front stage
Stock 5X7 rear fill
Hifonics BX1505D
TC-5200
