Go Back   Automotive Forums Car Chat > Peugeot > 306
Old 07-17-2006, 10:29 AM
mazza123 mazza123 is offline
AC in 306 diesel non turbo non functioning!
A/C decided to pack up today, in probably the hottest day of the year .
The control light for the aircon is illuminated and I hear a clicking noise ( i assume this is the compressor) clicking in and out but yet the air is tepid and not in the slightest cold.
Any ideas? Does it need a refill? I thought the compressor would not function if the refridgerent gas was low??
Thanks.
M
Old 11-17-2006, 12:06 PM
mikesmat mikesmat is offline
Re: AC in 306 diesel non turbo non functioning!
The compressor does normally not work but it depends on how much refrigerant has been lost.
A refill might work
http://www.peugeotdiesel.com/Air_Conditioning_2.html
but it's quite likely your AC pipes are leaking as it's a common problem on the 306.
Try refilling with a tracer dye.
www.programkeys.com
Old 11-17-2006, 12:27 PM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
A refill might work
Check the date on post before replying.
Let old dogs sleep.
Sometimes they bite if you wake them up..
Wal Mart DEATH KITS
You cannot properly and safely recharge an air condition system with them.
The one side stop and go gauge does not tell you what your system is doing or is over charged or undercharged.
A overcharged or malfunction air condition system can reach over 500 lbs of pressure.
Enough to blow up that can or system and freeze you at first and the burn you or blind you and if any propane /butane in there blow and light you up.
The stop leak crap and who knows what kind of oil in the kits there will stop your system for sure.
Just like pouring super glue in it.
And some kits even contain freon with a butane mixer.
Good for a big blast.
If you are going to do it do it right and safe.
Here is what you need to start with.
http://www.ackits.com/merchant2/merc...uct_Code=66773
In the older days you could just throw in a can and go.
But over the years just adding freon is getting harder to do.
Newer systems have to have the correct amount of freon down to the ounces.
Most will need pumped down and vacuumed down and the right and amount of oil and a set amount freon charge installed to get the air to cool right and the system to last.
If an air condition is low there is usually a leak that needs fixed and also a lose of lubricating oil from system.
Also air and moisture enters a low system
If you are going to try to do it get the proper type air condition gauge set with the low and high side gauges.
Hook up the gauges and get a reading with compressor running at idle and at 2000 rpm on the high and low side.
Post back pressure reading and we can help you.
MT
MT
