Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 07-17-2006, 08:33 AM
abebesheir abebesheir is offline
bad motor rod knock
First, let me apologize for my ignorance...
I have just bought a 1993 9c1 with a bad motor rod knock... I already own a 1992 9c1 with a badly rusted body and worn ring & pinion gears.
I want to use the engine parts from the 1992 to replace the damaged parts in the 1993.
What possible problem could a bad knocking sound indicate and what parts are required to fix this?
Would I be better off having a complete engine swap done?
Both cars have the L05...
Thanks for any replies.
John
Cars owned:
1991 9c1 w/L05 (no mods yet)
1992 9c1 w/L05 (no mods yet)
1993 9c1 w/L05 (no mods yet)
Old 07-17-2006, 10:42 AM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
Re: bad motor rod knock
A knock is usually indicative of a spun rod and/or main bearing(s). The repair is a replacement of the crankshaft, and whatever rods and pistons are involved, as well as new bearings and a new oil pump with screen.
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness!
1967 El Camino L79/M20 old school asphalt raper
Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have.
Old 07-19-2006, 09:22 PM
Thanks a lot, Silicon... the problem was the main bearing. I was still able to drive the car for two and half hours, despite the fact that the oil pressure was very low...
Cars owned:
Old 07-19-2006, 10:32 PM
silicon212's Avatar
Confoundingly Lucid
If it was a main bearing, you will need to have the block align-bored and then use oversize or "spacer" bearings. Don't think you can get away with simply putting a new bearing in it (or crank kit) or you will spin that bearing again, and fast, too. Probably when you fire it up the first time.
