Old 07-17-2006, 08:23 AM
jackmalone2001 jackmalone2001 is offline
o-ring replacement
Hello to All!
3.4l-1994 Chevy Camaro-5 speed
Lately I have been smelling a strong fuel smell coming from my car after driving. I do not see any evidence of fuel leaking from under the car, nor do i see any evidence in the engine bay so, after doing a little research on this forum, I believe I have some leaking o-rings on my injectors.
How hard of a job is it to replace the injector o-rings.
Can a someone perform this job in their back yard with a fairly good set of tools?
Are there any pitfalls/hard parts to the job?
I have not worked with the fuel system and would like as much information as possible before jumping in.
Thanks to all who reply!
Jack
before:
after:
Old 07-17-2006, 02:57 PM
97cavalier's Avatar
97cavalier 97cavalier is offline
Re: o-ring replacement
you know what , i think this os now a common problem for the 3.4's because my dads 95 3.4 has the same thing. After we get done driving it you smell this little gas smell, and it is not leaking any where under the car, so it has to be on the motor. But i do not see and fluid on the intake or any thing but if it is a little o-ring leak it probly just lets fumes out. they need clened any ways so i am going to full of his injectors clean them, put new o-rings and lube the ends and shove them in.
95 Z71 Silverado 4x4 ext. cab
Mods- Flowmaster Exhaust,Intake
Old 07-20-2006, 06:38 AM
Let me know how that goes! Good Luck
Anyone else have any information about fuel injector o-rings?
before:
after:
Old 07-20-2006, 09:39 AM
wrightz28's Avatar
wrightz28 wrightz28 is offline
is bring'n sexy back
I't been a while but you should have to only remove the 6 bolts holding the rail down, (I DO remeber the back left one is a SOB to get back in), disconnect the quick connectors, do to the orientation of the engine half way under the windshield it takes a little twisting around to manuever out. I don't remember if it was neccesary to remove the upper plenum, but it owuld probably make life ALOT easier. Once you have the assembly out, it's a breeze, just make sure to soak the rings for no more than a few minutes in clean motor oil before istalling.
Old 07-20-2006, 11:02 PM
97cavalier's Avatar
i always use vasoline on the o-rings, seems to work good.
